Etch priming over metal 2 metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2006, 10:16 PM
Is it ok to use etch primer over metal to metal and other bondo or should I etch prime first and then use bondo and metal 2 metal?
Any reccomendations would be very appreciated.
thanks.
Old 06-17-2006, 01:51 AM
Possibly not okay to do either one. You have to get a hold of the p-sheet for your etch primer. Some say its okay to use fillers over and over filler, but most have strict warnings to not do either. Self etch and polyester don't mix. If you are determined to use an etch primer and yours has warning against use of body filler, I would spray down your etch first, then follow that with a coat or two of epoxy primer within the time window to avoid having to sand for adhesion. What brand self etch are you using? Many P-sheets are available online, and they contain a lot of information about use that you should be aware of. Don't just go by the little bit that is normally written on the can. If your metal is clean, sanded and free of rust, I would just use an epoxy primer and skip the etch. Filler and epoxy is very compatable, and epoxy has good adhesion to bare metal.
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
Metal Finishing, to quote the great philosopher NIKE, “Just do it”. MARTINSR Body - Exterior 17 12-24-2005 11:08 AM
Metal Etch Better than Self-Etch Primer? unstable Body - Exterior 4 03-14-2003 11:04 AM
Priming metal in the winter, painting next summer? Norwegian Body - Exterior 19 11-15-2002 09:44 AM
