etching primer coverage - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2004, 08:48 PM
406 six speed
About how much etch primer will i need to do my 78 malibu wagon?And do they make a etch primer i can use to fill sand marks also?
Old 04-15-2004, 09:47 PM
i used 2 qts of vari prime on my 80 malibu jams ect 2 good coats dont know about hiding sand marks its thin
Old 04-16-2004, 06:29 PM
BarryK's Avatar
Etch primers are good for 400 grit scratches.
Epoxy (most) will cover 180 grit with one coat 80 grit with two coats.
Etch primers if a true one where one part is in a plastic or glass jug (the acid part) are not made to fill and should never be applied in excess.
