ETgenie - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2013, 09:30 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
ETgenie
What do you think??.
My website
A part of me says I should be concerned about a lean condition and damages-then there is apart of me that says it isn't much different than a part throttle.
Guys,opinions??.
Old 05-31-2013, 04:30 PM
Banned
bet you could use a drive by wire stepper motor and a volume knob(reostat) on the dash to set it. even those supwoofer amp wired gain control would work and be small enough to hide and or not hit while in the car,changing your setting
Old 05-31-2013, 09:11 PM
vinniekq2's Avatar
I would think pulling the timing would be easier
Old 06-01-2013, 08:27 AM
Banned
Originally Posted by F-BIRD'88 View Post
A lot simpler to just use a Qjet carb and limit the Air door opening as required.
Instead of building a big expensive engine or paying someone else to build this engine for you,
just build a simple cost effective low compression smaller engine say a 305 or 350 using off the shelf parts and
then supercharge it.
Engine power and car performance is adjusted by simply adjusting the supercharger pulley ratio.
The engine never runs hard enough to hurt itself. No exotic parts required,,, easy to maintain.. much more reliable.
A Weiand 177 blower will make this engine more than powerfull enough to run anywhere in the required ET range.
Can run may bracket classes. or dial power up/down to run top or bottom of the class.
Simple and low cost is better. It is a LOT MORE FUN
Drive it to and from the track.
have you seen what blowers cost lately. 2500.00 plus all the little crap that adds up. boost ref carb and fuel reg.
and wouldn't blown put him in a different class than the n/a would be in.
sounds like he's index racing not brackets
Old 06-01-2013, 09:43 AM
1Gary's Avatar
When I talk about a target ET of 11.38,it's for a lower end of a range of a ET class where the cut-off is 11.50.
With this devise I am somewhat concerned about leaning out the engine at the top end.The plan I have in mind is a 12.1 SCR or more,solid roller.
Old 06-01-2013, 10:40 AM
Banned
I like it, but hear ya, it be better if it cloed the hole like a camera lens shutter so the hole was centered instead of off to one side
you could take and make/but a carb hat, and pipe tubing to a cool air source and install a ls throttle body inline/between the airfilter and carb hat, and use the drive by wire motor to hold the ls t/b at the opening you want, with no effect on the airflow throught the venturi. and still be redkneck easy wire it to a 2 step and it could close it down at (rpm) in high gear to slow you down. keeping full power at 1-2 gear. it act like a throttle stop without being one, no idea how or if they'd call that legal.. one way to find out.
Old 06-01-2013, 01:10 PM
1Gary's Avatar
In the class I want to run a "drive by wire" or anything else like it would have to be OEM.
Electronic devises allowed is only a two step only.And data recording devises that can not be revealed during the run,but played back afterwards.I.E. a tach that shows the rpm during the run.
The faster classes is more of anything goes with delay boxes,throttle stops,etc.That is the classes I am retiring from.Like Hot Rod,Quick Rod,etc.
The possibility of this ET genie leaning out the top end question and the more complicated effect of flow is a question I have been hoping Techinspector 1 would chime in on.For sure I have heard of restrict'or plate racing in NASCAR,but never really looked into all what that meant.I mean we never build engines for NASCAR before and have a limited involvement in oval track racing in general.
Old 06-01-2013, 03:58 PM
Banned
but what I listed above isn't drive by wire. you still have the carb and throttle cable opening the carb..
the drive by wire stepper motor on the ls throttlebody would only be like a varible restrictor plate..controlled by the 2 step. with a volume knob (reostat) to pick your settings.
Old 06-02-2013, 07:25 AM
Banned
feel free to start a thread on that boost ref carb mod
Old 06-02-2013, 09:03 AM
1Gary's Avatar
Not one national winner isn't holding numbers in their package.Back door racers with the best drivers is hit and miss.
I do appreciate the time and suggests posted to this thread from everyone.Really mean that.
Climate minor changes does effect blower motors more the N/A/. That applies more so when taking into account my expectation of how critical I am in dialing the numbers for this car.So a blower motor of any kind is not under consideration.
The two fold logic for this BBC is a expression of how damm tired I am building engines for today's pump gas and if I break out of a class,the ability to position the car in the worsted case still saving numbers to end up in the middle of the next fastest class.
With we having won a national event,I know full well how that math game is played in bracket racing.
Still hoping Techinspector 1 will chime in with his math skills.This is even with lightening a heavy car and needs the torque of a BBC to cover numbers.I know where it should be at 60'/330',the mph in a 1/8.What I am looking for in the math skills Richard has is a correlation to a dyno sym given those 60'/330',mph numbers.The number to cover at the bottom of the sportsman class is 7.50,so I would want the car to run say 7.40.Then hold it back to 7.50's to keep it from running under using a say 4.56 rear on a 28" tire with a glide at about 3,000lbs.But because it will be the chase car,still be able to mph on the back haft of the run.
One question is if a 468 would be better than a 496 because of it's smaller stroke to buzz higher for the mph factor.The partnership short of the last five yrs has been all SBC's.Yrs ago we went through a period with 454 engines and problems with that,that we took a two yr break from racing and came back using SBC's only.It's only been the last five yrs that we have been using aftermarket BBC blocks with this yr's engine actually beening smaller than the other two engines before it and we are spinning it higher getting the expected results.The aftermarket blocks for this race deal is just not in the running,but as I said 12.5 SCR and a solid roller cam is in part of the plan and if needed a stroker kit.Also a engine build that isn't stressed much for longevity and consistency.
Richard please chime in with you thoughts.
Thanks everyone so far,
Gary
Old 06-02-2013, 09:53 AM
vinniekq2's Avatar
bore to stroke,I cant see how you could beat the 531? your original post said budget engine,which is why I said 454 flat tappet,,,
the 531 solid roller and 4.88 gears and you would have to shave seconds,not tenths.
looks like you are building a throttle stop engine but with a different throttle stop? Looking for top end drive around,controllable HP?put a "g-tech" and a stop watch on the dash and foot drive,,,
install a cruise control sensor from a mercedes that has variable cruise control with spacing sensor,,,wire it to a light instead of the throttle,,,
use a VVC with a manual lock? on inboard limiter,
use a gps/g-tech with a count down 1/4 mile guage,,,
and like I said before,a timing pull back,,
I see the budget has changed
Old 06-02-2013, 10:10 AM
1Gary's Avatar
Vinnie-I get your point and to build a high compression solid roller 468 may very well be the best plan.Thing that has me thinking is breaking out of the sportsman class and ending up be the car being chased.Before I got involved in the 9.90 cars with my partner,I do have some not some not fond memories of being just out and out beat.On my dial,with decent lights and still losing.
Old 06-02-2013, 12:38 PM
Proud LOSER
I watched someone do this in 30min last week....and it flat out works....pretty cool.
Blowthrough Carb How-To
Old 06-02-2013, 01:54 PM
1Gary's Avatar
This is not true.. Do not confusel a 11sec supercharged street blower car with a promod or A/FC car where track conditions cause the variance in ET.
The ET class you will be running will not support running a race gas motor. You will get reall tired and broke real fast. The simple supercharged SBC car will be more consisitant/much easier to set the performance level
and LOT cheaper to operate. The 11's don't pay much to win.
The only classes that will pay enough to win will be ones you ahve to qualify for (quick 16 field etc).
The supercharged car allows you to do this. easily and for less.
Your plan will end up $30K in a 12sec malibu that is not completive. and no fun.
Powerglide big mistake.. You want a th350 or th400 that auto shifts all by it self. race in D.
Consistantcy is what wins.
This is a 12sec car not a supergas car.
The win money is $300 and pays back to four places without being involved in the points.Being in the top four wouldn't be a bad result for the points by the end of the yr.
Sure 15k to 20k is likely.Just want to bring some professionalization to the class.
The glide part of it is exactly for the sole purpose of consistency.Few shifts is more consistent.Proof of that is in the super classes.
I've spent the better part of my life cost benefiting race cars to turn racing into a profitable business.It's from that I am retiring from to just have some fun doing laps.Yet I hear ya about costs.It is very easy to allow the hot rod in me get away from me.It is one reason why I am restricting this build to cast iron heads either OEM or aftermarket.Also on the hunt for a car that is partially built at a good price.
Old 06-03-2013, 07:38 AM
vinniekq2's Avatar
lots of 11 second powerglide cars.mostly small small blocks or class cars. the power glide cars hook,though the malibu hooks well anyways
