how would I know if my car can run off e85? it's a 2000 Pontiac Grand Am SE with a 3.4 "3400"v6 under the hood. Basically a 3.1 "3100"v6, and a 2.8L v6. Just updated, and different bore/stroke.
go to http://www.e85fuel.com/ and click on "flex fuel vehicles" - on the left side of the page for a complete list. Your Grand Am is not listed there.
Tom http://www.e85fuel.com/faqs/e85.htm |
I have a couple of golf tees that are made from corn. They feel like plastic, but are biodegradeable. That way we can use oil for better things; like gasoline. Then we'd have enough supply so it'd be $0.85/gallon (I wish) like when I was a little squirt. Corn prices would go up since it'd be used for making plastics also.
Ethanol
Most of the pumps in the country or at least in major cities right now have anywhere from 8% to 12% ethanol in the fuel for emission purposes. The problem when you go to higher % usage like the E-85 is like Methanol it will absorb the moisture out of the air. This will corrode the internal components of the engine, increasing the maintenance costs. There are pros & cons on both side, but I don't think you're going to see a wholesale change in the near future.
I did a research paper on the use of E-85. The government is really dropping the ball not making this available at every gas station in the country.
do tell what you found out in your research...I am curious about getting some E-85 to try here in new york. My main question is if it is safe to use in a gas motor with no mods?
There is no incentive for the Government to do anything. Until the Ethanol industry can fill the pockets of the politicians like the oil company's do things won't change. The recently passed energy bill requires 7 billion gallons of ethanol used for fuel over the next few years, the ethanol industry wanted 8b mandated and the oil company's were pushing for 5b.
One of the big oil's arguments were that the additional ethanol mandated would raise gas prices.???????? |
When using ethanol have your carburetor plated in nickel.It will last forever.
Fuel lines should be converted to plastic.Fuel pumps and tank sending units should last a few months. Due to the totally different stoichiometric air fuel ratio expect about 40% higher fuel consumption.Gasoline runs at 15:1,ethanol at 9:1.At lot less air for the same amount of fuel. When carbureted it will never cold start bellow 50F.The way around is a little electric pump to give it a shot of gasoline from a small recipient.Once it starts expect about 3 minutes minimum of warm up before you can slowly move the car. If it is not subsidized by government ethanol will always cost more than gasoline even at todays prices. |
I avoid it like the plague when I go to Illinois. Second.. Ethanol was commonly used as engine fuel 75 years ago. It was called moonshine/whitelightning.... Consider too, LP gas has 145 octane, but the BTUs are so low, you get only about 2/3 your original gas mileage. |
Currently around central IA gasoline with ethanol is .10 a gal cheaper although it receives a .04 a gal tax cut, why the .06 difference ? |
Probably someone already told you about brazilian alcohol fuel. It's basically the sabe thing you're asking about ethanol. Well, here some facts:
We used it since late 70's or early 80's (don't know cos i'm too young to), but here are the facts: The carburated cars used special niquel-plating carburators and fuel pumps, 10:1-12:1 compression ratios, and a Gas cold-start system. Hard to start on cold (less than +15ºC cold, not snow cold), but 10 to 20% more power than gas ones with less fuel efficiency. After 1989-1990 we had our first's eletronic fuel injected alcohol cars, the cold start problem was fixed with a richer mixture for cold water temp. once the "new car magazine - 4 rodas" tested an alcohol cold start car inside an industrial refrigerator (under -25ºC) and id started perfectly. After some years of non alcohol cars been made now we have the "flex-fuel" tecnology, whitch is a new hope for us high performance lovers, cos our high-output fuel was disappearing from gas stations... now it's back! |
All this talk about getting an engine to run on the stuff has me wondering... What will become of catalytic converters? Will we need them, or will the hydrocarbon/CO biproducts be negligable with ethanol/gas? Also, for all of the turbo, and good tuning, folks out there using EGT and Air/Fuel gauges, will these values change to the point we'll have to relearn what to look for good/bad? I guess we'll just have to wait around to see who starts doing it first and writes all the "how to..." books and makes money
