ethanol in fuel and pump diaphragms - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2010, 05:10 PM
Would it be a good idea to replace my rubber pump diaphragm's on my Holley with their green diaphragm's,due to the ethanol in gas, which are designed for alcohol based fuels? This is on a vehicle that sees maybe 2-3000 miles a year.
Old 07-10-2010, 04:06 AM
I bought a 1970 Chevy PU from about 1975 and rebuilt everything that year. I didn't have any problems till they added alcohol to fuel. The only thing that went bad on my 70 chevy PU with a 350 engine was my carb. The alcohol messed up the rubber parts and it flat stopped working when I was in town one day. It happened pretty fast too. I changed carbs to an Edelbrock and never had the problem again. I never had to replace the fuel pump or anything else and drove it for many years till the engine wore out and started smoking. Most all parts with rubber were upgraded to be resistant to alcohol in fuel after alcohol was added to fuel.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 10:01 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 03:54 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
