ethanol and rubber fuel lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2012, 03:13 PM
ogre's Avatar
the 'Duracell Project'
i bought a fuel tank for my 58 chevy truk from no limit engineering a couple of years back. it has an in-tank fuel pump for the 350 ramjet efi. according to the ramjet manual, i only run premium fuel in the tank. the original in-tank fuel line that connects the pump to the tank outlet lasted exactly zero miles.
when i pulled the tank and pump the fuel line was in shreds. it was clearly marked ''not for submersion'' on the line. i wrote no limit and got no response from them. i replaced the line with a gates rubber line that was marked ''for submersion in fuel'' on the side. it cost me $29 for a one foot piece.
i get an average of 6 months or 2500 miles between fuel line failures. the last time was coming back from dallas on the power tour. i lost fuel pressure in the middle of kentucky. luckily i knew someone nearby with a garage, no tools or a jack but at least i didn't have to drop the tank on hot asphalt. i bought a $19 jack and $19 jack stands from a parts store, dropped the tank and cut an inch of the line to get back home.
the pump is your basic gm in-tank pump. the current line is 5/16'' rubber line from the pump to the outlet with screw clamps on each end. every fuel line replacement i have seen is rubber line.
what can i replace the line with, that will not be affected by the ethanol in most fuel now days?
this is the typical failure for the last 3 times. the line fails right above the clamp.
this time the whole line is soft from ethanol exposure, but the repair got me home...
Old 06-23-2012, 04:34 PM
bullheimer's Avatar
NEVER use credit cards!
I'M SEEING that people have had great luck with PLASTIC hose.
Old 06-23-2012, 06:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Would it be possible to replace that line with a hard steel line?? might look at that..
Sam
Old 06-23-2012, 06:59 PM
delawarebill's Avatar
fuel line
when i built my bucket 10 yrs ago i used fuel line from a roll at pep boys. never had a problem.. but then i'm only running 4# from my elect pump..
Old 06-23-2012, 07:27 PM
LATECH's Avatar
Plastic is the way Ogre.
If you can find it. You can buy short pieces of black plastic fuel line in a repair kit. It usually has acouple barbs in it to join the lines together.
Here is the deal, the line is pretty tough, and it takes a strong hand to push the plastic on the barbs. But it will stay once it is on and withouth clamps. I have done this many times, it works. However... I realize you have no barb on the pump OK. You can buy a brass compression fitting that goes from tubing on one side to a hose barb on the other, that will work good for the sender tube side, as far as a Barb on the pump probably not going to happen.
If it pushes on and goes on tight, and you can put a Small fuel injection style clamp on it, (real small, but available) youre in business.
One other option , many newer GM pump modules with the sender and pump, have a convoluted plastic tube on them from the pump to the sender tube.Those plastic flex hoses are very durable, in fact They last quite well for 8-10 years in the stock application.
I see it all the time when I replace a pump.You could buy a pump assembly for say... a Vortec engine, and take out the pump and hose and put it on the sender you have. You will notice that they use a very small oetecker style clamp on them. These dont fail, and neither does the plastic hose.
I did 50 fuel pumps last year, and only one I saw had a split in the plastic line. It was 15 years old.
You may be abl to scrounge the plastic line from an assembly that is being replaced, and re use it ( I bet you dont like the sound of that ) taking care to get new Oetecker stlye clamps or carfully removing the old ones for re use.
I Know ...used parts. Hey, I know it will work, and it wont remove a limb just to purchase it. peace man.
Fact is stranger than Fiction
Old 06-23-2012, 07:34 PM
LATECH's Avatar
The white flex hose is the goodie that you want.Just clamp her on to the pump and sender tube and ...voila.
ID:	66279   Click image for larger version
Old 06-24-2012, 05:15 PM
ogre's Avatar
hard line won't work, the pump has a barb on it.
i'm trying to find find a plastic line that will work on both ends. we just tossed a bunch of old units that may have worked from mustang pumps. i had to google Oetecker, i've seen them before and successfully reused the clamps with pliers on oem apps. i'm not happy with the response i've gotten from no limit eng.
i'll try to find a plastic convoluted hose to reuse. all the oem's have gone to this it appears.
thanks for the replies.
Old 06-24-2012, 06:35 PM
LATECH's Avatar
Nice truck BTW.
Old 06-24-2012, 07:48 PM
ogre's Avatar
Thanks. When it runs.
Truk did do the power tour and then some before breaking down
3732 total miles
Bad rubber fuel lines ScoTFrenzel Hotrodding Basics 4 01-06-2009 02:48 PM
background infomation about ethanol fuel mina Introduce Yourself 1 06-10-2007 12:30 PM
Rubber transmission lines? HotRodMan Transmission - Rearend 1 10-21-2006 09:37 PM
10% Ethanol fuel Greg Bull Engine 18 05-15-2006 10:37 AM
Ethanol Fuel ChevelleSS_LS6 Engine 53 02-02-2006 01:39 PM
