Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eurathane newbie
Old 06-11-2012, 11:02 PM
R.sok R.sok is offline
You could try wetsanding instead of dry sanding. Also before any sanding wash the car down with dish soap to take off any wax or grease/ dry then use a wax & grease remover. If it still loads up then my guess is he didn't use enough activator. As for gun options if you are good at painting with your devilbiss gun then there is no reason to switch over unless you want less overspray that a hvlp offers
