Evaluation of engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2004, 09:32 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
If you all would, run these engine specs through your engine analyzer programs and post the results. Use as many different programs as you can and include which program in your replies.
350 ci - 4" x 3.5"
5.7" rods
Vortec heads - 1.94 / 1.5, 64cc, 9.1 total cr
Cam - lift: .435" I, .460 E / Duration @.050 212 I / 222 E
1.5 production rockers
Part # 12496820 Dual plane intake
600 cfm vacuum sec. Holley
Stock exhaust manifolds - open
This is a little experiment and I appreciate your help.
Old 10-21-2004, 04:36 PM
Lonestar's Avatar
Come on people!! It would only take you a few minutes to punch these numbers in.
I have my own calcs but I need a variety to validate.
Old 10-21-2004, 04:42 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
People usually jump at the opportunity to punch the numbers in on here.
Anyway
Those are the specs for GM H.O. 350 Crate motor. 330 hp 350 tq. Actually underated, Car Craft dynoed one last november. It made 20 more horsepower.
Old 10-21-2004, 04:46 PM
Lonestar's Avatar
I know what it is, I just want to see what everyone comes up with using different programs. I chose it because of its simplicity.
Old 10-21-2004, 04:52 PM
My figures HP and Torque figures are a by product of designing the right cam and consiquently always low. Guess you can't get everything for 20K in programing.
Chris
Old 10-21-2004, 08:28 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
I get 339 hp @ 5500 RPMS with 396 ftlbs of torque@3500 rpms with desk top dyno.
Old 10-21-2004, 09:09 PM
Grumpy
384 Ft Lbs at 3500
321 HP at 5000
Limiting factor is the carburator which for that CI and cam is too small, also can not select open manifolds. Choices are manifolds stock exhaust and HP exhaust W manifolds, or headers W, or W/O mufflers. I selected headers W/mufflers, should be about the same.
With a larger carb(750-780 CFM)
387 Ft Lbs. at 3500
326 HP at 5000
