Ever see a V-12 fired up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2005, 04:25 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
This is so *****in, I think I wet myself. If you never seen a V-12 fired up, check this out.
http://w1.132.telia.com/~u13203489/ItsAlive3.MPG
Old 11-09-2005, 04:36 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I think he left some parts off of it
Old 11-09-2005, 04:39 PM
anyone what kind of v12 it is? allison? merlin? cause whatever it is I want want one!!!!!
Old 11-09-2005, 05:34 PM
Wiki Edits: 647
Its a Rolls Royce aka Rover Meteor is what it is known by. Check out his website link of a buildup of the speedster.
http://www.brandow.tk/
and go to the speedster link at the top of Page.
Old 11-09-2005, 06:21 PM
MI2600's Avatar
Member# 3287
The one I liked was the clip of the P-51 engine in a car...somewhere in Norway??
Old 11-10-2005, 10:25 AM
Wiki Edits: 647
Did you see the picture of the speedster when it was finished? Check out the link to see the car.
Would you call those 'short' pipes Z O O M I E S ! !
Old 11-10-2005, 10:40 AM
302 Z28's Avatar
Nothing quite like the sweet sound of a Rolls Griffon in a Spitfire, or a Packard built Rolls Merlin in a P51 to make the hair on the back of your neck stand up .
Vince
Old 11-11-2005, 06:00 AM
coupe66's Avatar
MI2600, not from Norway... its a normal Swede...
Old 11-11-2005, 06:23 AM
MARK TINNELLY's Avatar
87 AEROCOUPE
Rolls Royce Engines
Yeah, The Rolls Merlin, In 1944 Produced Just Over 1000hp To Power The P51 Mustang And Later The Spitfire & The Hurricane, What An Awesome Sound To Any Motor Head, Did Any One Ever See The Head Been Taken Off An Early V12 Rolls Engine?
It Is A Site To Behold, There Are No Head Bolts, The Heads Are So Perfectly Machined That They Used Steel Dowels And Then Heat To Expand The Dowels, To Take The Heads Off You Must Suspend The Engine By The Heads And The Bottom Will Simply Drop Off After Around 5-6 Hours, It Is An Unbelievable Piece Of Machine Work For That Time.
Old 11-11-2005, 07:29 AM
Bad Rat 414's Avatar
www.bigblock67chevelle.co m
I've seen hundreds of V-12's crank up. Diesels.... How about a V-12 Detroit with twin blowers and twin turbos and intercoolers!!!
After looking at the video I see that it is a Detroit diesel. That thing will slobber oil all day long, right out the slobber tubes.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Want 12 volts ,have 2 6 volt batteries. moodier Electrical 12 10-09-2005 07:35 AM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-29-2004 12:41 AM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 11:59 AM
SBC Timing indexing a unmarked 4.25 blower hub and custom tab 614streets Engine 9 06-14-2003 05:26 PM
