Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer
Old 05-27-2006, 08:53 AM
oldred oldred is offline
Better listen to what these guys are saying, I was still using lacquer primer when I came here because I simply did not know any better. The only thing I can see using lacquer primer for now is if it is used for a guide coat but there are better products for that. Why would you use such an outdated inferior product under a modern paint system? And it is just that, a system that requires compatible components of which lacquer should play no part.
