Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2006, 08:37 PM
scrot's Avatar
I have a can of the Slick Sand sitting in my freakin' lap. It says excellent adhesion to:
  • Metal
  • Galvanized Metal
  • Aluminum
  • Wood
  • Fiberglass
  • SMC
  • Body Filler
Notice sanded original finish or 2K primer surfacer, or lacquer primer surfacer is not listed!
What the heck is this crap?
I can't see this being an accidental oversight by Evercoat.
What say you, professional painters and body personnel?
Does this mean the Slick Sand will not adhere to the other primer surfacers
[lacquer in my case] that is already covering the panel ?
I searched for info, but I didn't find an answer. The reason I am using lacquer is because I have a gallon of it, and I needed something to cover the exposed metal before I bought the Slick Sand
Thanks.
Old 05-26-2006, 09:07 PM
http://www.evercoat.com/imgs/pis/SLICKSANDPIS.pdf
Go down to 'approved substrates' which include OEM finishes as well as refinish finishes.
Larry
Old 05-26-2006, 09:31 PM
Why are you using lacquer primer? Most will agree that it's old and outdated with 2k and epoxy primers that we have today.
Old 05-26-2006, 09:41 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Scrot you have worse problems to worry about with lacquer primer as your surfacer... You would be far better off using kirker, marhyde,montana, northstar,transtar etc Urethane primer surfacer... Those are dirt cheap and not the best by far, but they are tons better than anyones lacquer primer
Old 05-27-2006, 08:53 AM
Better listen to what these guys are saying, I was still using lacquer primer when I came here because I simply did not know any better. The only thing I can see using lacquer primer for now is if it is used for a guide coat but there are better products for that. Why would you use such an outdated inferior product under a modern paint system? And it is just that, a system that requires compatible components of which lacquer should play no part.
Old 05-27-2006, 11:08 AM
41' Chevy Master DeLuxe Tudor
Last journal entry: Engine/Trans Mock-up
Wiki Edits: 2
Nothing like a good Epoxy primer. I've used the Omni line of PPG with good results for what it costs. I also seen some pics of a fellow member evill which he sprayed Southern Polyurethane's black epoxy primer on his 911 Porsche project. Here is the link if it works.
My 911 Project
Using the black I think would be a good idea because it looks like it would show imperfections better. I don't think the SPI is real expensive either.
Old 05-27-2006, 02:27 PM
scrot's Avatar
Thanks, lbell101
Looks like I am S.O.L. I'll have to sand off the lacquer.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Rolling on polyester primer. MARTINSR Body - Exterior 15 05-31-2006 07:55 PM
polyester primer surfacer 62galaxiguy Body - Exterior 4 02-14-2004 08:27 PM
evercoat primer not hardening Dawger Body - Exterior 13 11-22-2003 12:07 AM
Sealer or polyester primer first? Cowtown Punk Body - Exterior 2 06-30-2003 04:20 PM
