Evercoat Super Build 4:1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2011, 05:20 PM
boris_thespider's Avatar
I'm building a fiberglass kitcar and was thinking of using Slick Sand. Since Evercoat Super Build 4:1 goes on thicker, would using this allow me to eliminate a coat or two? Or would I be better off with thinner, multiple coats of Slick Sand? Thanks...
Mike
Old 02-03-2011, 08:24 PM
Rag top bird's Avatar
Hot rods are still the king
Mike
Slick sand is a good primer it builds fast and you will need reducer to get it to lay down because it is so thick but watch it it will set up in the gun before you know it
Old 02-04-2011, 05:16 AM
havent used the 4:1, but planning on it soon. Slicksand, sprayed through the right tip, you need no reducer or thinning agent. I use a sata poly gun, belive it is a 2.5 tip. If you want to reduce, use acetone. Acetone wont affect flash times, as a urethane grade reducer will some.
I would probably use the 4:1 on a fb body, especially if it is a hand laid body. I believe it would cut down on the number of coats using it. I would say 2 good coats of it would equal 4 coats of slicksand, according to the mil thickness in the spec sheets.
Old 02-04-2011, 06:32 AM
Evercoat says to use a 1.6mm to 2.2mm tip for Super Build 4:1. They recommend at least a 2.0mm tip for Slick Sand. I don't quite understand why you can use a smaller tip with Super Build when it lays down a heavier coat. Anyone have any ideas?
Build/Rebuild Super T10 Help mrdreex Transmission - Rearend 1 04-15-2009 02:44 PM
Super rare Pontiac super duty found on auction... F&J Hotrodders' Lounge 40 11-17-2008 07:37 PM
Evercoat Que. 39chevy Body - Exterior 2 05-28-2007 12:06 AM
Evercoat Uro-Fill 2k. Anyone? shoddy_f-body Body - Exterior 1 08-24-2005 07:18 PM
evercoat primer not hardening Dawger Body - Exterior 13 11-22-2003 12:07 AM
