Everyone needs a sheetmetal gauge. :) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2013, 06:41 PM
I was using one of my sheetmetal gauges and thought I'd bring it up here. It's a very well spent $20 and often overlooked. If you are working on these old cars fabricating things you need one, you won't be sorry.
Sheet Metal Gauge
Old 07-28-2013, 08:07 PM
sedanbob's Avatar
Where can I get one of those for fiberglass? Just kidding!!
Old 07-28-2013, 08:12 PM
You know what Bob, this one would work for glass. I can't see why you wouldn't want it too if you were replacing a piece to know you have similar thickness. Or doing a repair if you have an edge of that repair to check to ensure you have enough material, I can see it having a use.
Old 07-28-2013, 08:47 PM
sedanbob's Avatar
Brian, it could come in handy if you were making a new panel. If you need to bond a new piece into an existing panel, you usually have to grind both sides down and lay in new glass. You grind away most of the original thickness as you start the repair.
Bob
Old 07-28-2013, 08:54 PM
Yeah I guess it isn't as critical as metal, oh well I guess I was thinking too much. I am thinking the thickness varies all over the place too, not like the steel where it's critical that it matches.
Old 07-29-2013, 06:01 AM
Irelands child's Avatar
Brian - looks good.
But since I an kinda cheep ($20 is a case of my favorite adult bev and a bag of Fritos), just drop my little, but reasonably accurate ancient 1/2" mic in my lint filled pocket along with an internet found gauge chart and wander off to the metal guy.
Dave W
Irelands child
Old 07-30-2013, 06:01 AM
Faith - Respect - Trust
Hey Brian, I have had a sheet metal gauge in my tool box for over 20 years and never used it, all I was doing was late 60's early 70's restorations and some fabricating and much of the metal I was using was standard size for that era...then about 3 1/2 years ago, I took on a 1930 Model A...and needed to replace some metal, it was lot thicker than what I had in stock and wasn't sure how thick or what gauge I needed. I took out the old metal gauge and soon found out.
Now I've got 2 projects on the go, one is another Model A and the other has aftermarket panels...I'm finding I use that sheet metal gauge almost daily. The Model A was 4 door turned into a 1/4 ton truck and there is a lot of fabricating to do and the other with aftermarket parts, well it seems every piece of metal is a different thickness. So yes, that gauge has come in handy lately, maybe it should have in the past as well, just happy I'm using it more now and your right, anybody and everybody doing this type of work should own one.
Ray
Old 07-30-2013, 06:30 AM
Banned
Originally Posted by Irelands child View Post
Brian - looks good.
Dave W
yup and/or a spart plug gap'n tool..
Old 07-30-2013, 11:47 AM
sedanbob's Avatar
I agree that gauge is a handy tool to have and everybody ought to have one - I just couldn't pass up the opportunity to tease you.
Bob
The Following User Says Thank You to sedanbob For This Useful Post:
MARTINSR (07-30-2013)
Old 07-30-2013, 03:08 PM
cyclopsblown34's Avatar
Colorsanding painter
I keep a little 1" square one on my keyring...quote handy, it was a promo thing one of my customers was giving away years ago.
Old 07-30-2013, 10:15 PM
Semper Gumby
Wiki Edits: 2
I'll make one up for you. Do you prefer 2X4 construction or plywood?
Old 07-31-2013, 09:11 AM
sedanbob's Avatar
Either would be fine... I don't suppose it would fit on my key chain? Thanks!
Need sheetmetal help Gr8 '48 bow tie Body - Exterior 5 08-20-2011 07:06 AM
replacing factory in dash oil gauge with aftermarket gauge Torque454 General Rodding Tech 3 09-06-2010 01:34 PM
Sheetmetal Furytom Body - Exterior 11 09-20-2008 07:02 PM
gauge of sheetmetal to use ? 49olds Body - Exterior 7 03-25-2004 06:12 PM
Sheetmetal? Deadtemple Interior 6 09-15-2003 03:21 PM
