Everything is lifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2008, 07:10 PM
Derkyb's Avatar
Ok, I'm a beginner painter and im learning mostly by trial and error method. My problem is this: recently I was color sanding and buffing the car, it was turnining out beautifully until the last few inches I needed to buff and thats when the buffer jumped and burned through in two places, darn! So, Ive sanded these areas down and feather edged nicely but I had to go back down to the base. I put on some polyester filler and noticed very small cracks forming where the filler touched the base. I thought I could cover it with primer but thats when it really started lifting. I resanded back down to the base and tried to glaze it out no luck it turned everything to putty. I'm using Nason base/clear and there is a very strong odor when sanding to the base like the paint is still wet/evaporating, but it has been painted for almost three years now. What can I do to stop the lifting now?
Old 09-03-2008, 08:36 PM
Countilaw's Avatar
Cox Custom Cars
Sand the entire area down to the basecoat. Then mix some epoxy reduced to a sealer as per instructions on the P-Sheet.
Seal the entire area. Using a scotchbrite pad, scuff the area including an area beyond the sealed area.
reapply you base coat but do not go past the sealed area.
apply three coats of clear coat and go to the edge of the scuffed area, but not past it.
After cured, Wet sand with 1200, 1500 and 2000, out past the scuffed area. Then buff to a high shine.
Frank
Old 09-03-2008, 09:33 PM
Derkyb's Avatar
Thanks for the quick reply I will get some sealer
tomorrow should have it painted by the weekend thanks!
Old 09-04-2008, 07:48 PM
adtkart@aol.com
You didn't say what color you are dealing with, and that could make things more difficult. You also didn't say where the spot is at that needs to be fixed.
That being said, I would not try spraying the clear only in the damaged area. You should clear the whole panel. The area will likely be noticeable if you try spraying the clear only in the area of the damage, unless you use a clear blender, and still may show it's ugly head.
Aaron
Old 09-05-2008, 06:04 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Don't lay the primer on wet. Give it more of a dry coat. A wet coat will eat into the base and cause it to raise.
Old 09-05-2008, 08:52 AM
If this spot is still small, don't make it any bigger.
What is happening is the solvent is getting under the clear because the paint is soaking it up. So, over the clear, there will be no problem, only if you spray something over the base will you get the lifting. The finer the paper you are sanding with the better. If the paper is too coarse it leaves scratches for the solvent ot get into the base as well. So go over it well with 400 or so.
So, to seal off that base is what you are after. All you need is a "shell" over that base, with the least amount of solvent to soak down into the base.
Sooooo, as mentioned, spraying kinda "dry", spray VERY light coats with LOTS of flash time in between you can build up this "shell" over the base.
Old 09-05-2008, 08:53 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Nason is a poor quality paint IMO.
If you are having lifting problems after 3 years, you're going to have a difficult time trying to get this problem fixed.
Even if you get the edges to stop lifting - it's guaranteed you're going to experience massive shrinking in the area afterwards.
You've got 2 choices, just patch it up the best you can and understand it will never be perfect - or - strip the Nason paint off and start over...a paint job is only as good as what's underneath.
Engine lifting plates 57halfton Hotrodding Basics 15 02-06-2008 07:15 AM
lifting a ford truck back up?? tiresmoke55 Suspension - Brakes - Steering 2 08-27-2006 08:20 AM
Engine lifting? Steves66 Engine 14 01-30-2006 02:44 PM
hey do i need to brase the cab of my short cab pic up befor lifting it off my frame mopar_101 Body - Exterior 7 07-19-2004 07:28 PM
lifting an engine 1961_MGA Engine 5 10-16-2003 12:15 PM
