Excess oil pump shaft clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 09:12 PM
Pre-assembling my 400 sbc and have found excess pump shaft clearance. Mocked up with all new parts,Melling M55HV pump, ARP shaft, MSD HEI, Patriot heads and performer RPM intake with no head, intake or dizzy gaskets and have 0.090" when I should have around .010 to .040".
I am running an oil baffle plate between pump and main cap so that adds .050 to the clearance. (without it, it would be at the .040")
What is the best solution to get this back in spec? Machine down intake to allow dizzy to sit lower?
Old 03-15-2009, 04:26 AM
ericnova72's Avatar
More for Less Racer
You can't lower the dizzy because you will badly mess with the gear mesh at the cam. You are worried too much about this spec, the shaft is meant to float between the pump and dizzy. Put it together and run it.
If you're anal about it and have to have it in spec, you will have to have the bottom of the pump machined, which is another issue because it might weaken the pump.
Don't worry about it.
Old 03-15-2009, 09:54 AM
Thanks for the kick in the ***. First complete build so have been a little anal alright. Moving on...
Distributer-oil pump shaft; not the "usual" problem 307malibu Engine 7 11-04-2008 12:46 PM
1968 - 1969 YW block. I can't find a DISTRIBUTOR that fits the oil pump shaff Bryan Meier Engine 5 06-16-2008 11:15 PM
oil pump shaft problem BringBackTheCamaro Engine 2 04-13-2007 09:29 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
oil pump drive shaft. christopher406 Engine 7 01-30-2003 06:42 PM
