Excessive brake pedal travel......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 08:26 PM
I have a 1988 Lincoln Town car with a 302 and power everything. I had my brakes worked on at a garage (new pads, shoes, rear wheel cylinder on drivers side, rubber hose on pass. front). Ever since, the brake pedal travels at least halfway down, but the car stops OK for city driving. I was not happy with the pedal, so the guy adjusted the rear shoes almost all the way out (rear brakes dragged........ ). I told him I think the brakes need bled, but he said they were. I recently tried to bleed all 4 corners (able to do both fronts, and drivers rear, but pass rear bleeder is stuck and stripped). This had no effect on the pedal. I also replaced the master cylinder gasket, which also had no effect. I adjusted the rear brakes so they don't drag anymore, but what could be making my brake pedal so spongy?
Old 05-10-2007, 10:02 PM
did the pedal feel change when rears were adjusted......(they should drag little )
Old 05-10-2007, 10:19 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
This happened to a friend of mine with a ford also, something about
bleeding something in the anti lock system, I'm sorry I can't remember
just what it was, He took it to ford, problem fixed.
Good luck,
rich
Old 05-11-2007, 05:58 AM
Wiki Edits: 31
yeah, if the brakes are not bled in order, the ABS will screw up the pedal. call ford, and get a bleeding procedure. normally it's closest to the master cyl first, and farther away as you go, so like lf, rf, lr , rr but who knows with the ABS system, it may be diffrent
Old 05-11-2007, 06:16 AM
classic cruzer's Avatar
I always thought it was farthest away from master cylinder first, rr,lr rf & lf, Iam I wrong?
Old 05-11-2007, 06:43 AM
I don't think this car has ABS. It dosen't have any idiot lights for it, and dosen't have an air bag either. Adjusting the rear brakes had no effect on the pedal.
Old 05-11-2007, 10:43 AM
So you've only been able to bleed three of the four wheels? You still have air in the system.
Old 05-11-2007, 01:47 PM
you still have air in the system best way is to bench bleed by opening all caliper bleeder valves and let gravity do the work takes about an 1hr but works good should solve the soft pedal than bleed in order starting with the furthest from master cylinder. if that does not solve the problem maybe a seal in the master cylinder is know good
Old 05-11-2007, 01:49 PM
also adjusting the rear will not solve the pedal problem air in the system is your problem.
Old 05-11-2007, 04:29 PM
I wish that mechanic would have believed me whae I told him this.......
I think I got screwed, won't go there again.
Old 05-13-2007, 07:07 PM
Wiki Edits: 31
you want to force all the air out, so you force all the air out from the master cylinder back, otherwise you could put air back into another line closer, if you go farthest- closest
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 10 12-23-2013 10:47 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Brake Pedal Travel yooper Suspension - Brakes - Steering 3 04-23-2004 01:34 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Manual brake pedal travel jpd37 Suspension - Brakes - Steering 8 05-22-2003 12:17 AM
