Excessive Brake Pedal Travel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2011, 05:38 PM
Russgolfs's Avatar
My 1941 Chevy's brakes work fine, I just have too much free travel before the brakes start working.
It's a power brake system with front disc's and back drums. The proportioning valve is on the frame well below the MC and booster. The pedal travel has been like this since I bought the car 3 years ago.
I have replaced the brake fluid, bled the system, and adjusted the rear brakes with very little improvement.
I recently taped 3 small nuts together and put them into the MC where the booster rod would go. It brought the pedal up but also applied the brakes so I took them out. Did I just prove that the brake pedal rod is too short?
I looked at my brake pedal rod to see if it's adjustable, it doesn't seem to be unless the adjustable part is on the other side of the firewall and into the booster.
Can I buy a longer brake rod? Do I have to lengthen the current brake rod? Any help would be greatly appreciated.
Russ
ID:	57831   Click image for larger version
Name:	1941 Left Side Engine View.jpg
Old 08-29-2011, 04:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Sounds to me like your pedal travel is too long (under dash stop adjustment), or the pedal swing geometry is wrong, and the rod too long lifting the pedal to that high position. Do you need all that travel?
I've seen brake pedals (hanging) with multiple holes to mount the push-rod to that would lower the pedal. On some GM power booster to MC plunger, there are different length push-rods as well, two sizes I'm aware of, that would effect plunger depth, too short and it doesn't push enough fluid, too long it bottoms out in the MC.
Semper Fi
Old 08-29-2011, 05:12 PM
Russgolfs's Avatar
Yes, way too much travel before brakes are applied. Can I remove the rod from the pedal and go buy a longer one? My brake pedal is straight in the area where the rod attaches so I don't think I'd get much more travel if I lowered the rod on the pedal. The rod is supposed to be horizontal as much as possible right?
Old 08-29-2011, 06:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the travel is really "free", i.e. the pedal/rod assembly does not contact the piston until the pedal is depressed some distance, then there are a couple choices:
Lengthen the push rod.
Adjust/modify the pedal stop.
Usually a power MC piston will have a shallow push rod hole, or will use a spacer to make it that way. So be sure the MC itself and the MC piston's push rod hole is compatible w/the pushrod you're using.
If there IS contact w/the piston after just a little pedal movement, yet it still takes a lot of travel to get the brakes to engage, the master cylinder bore may be too small or the calipers/wheel cylinders too large or the pedal ratio is too high. Try the lower hole first (if you have one, that is).
Old 08-29-2011, 07:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another thread reminded me- is the MC on the firewall or below the level of the calipers, or ?
Old 09-01-2011, 06:15 PM
Russgolfs's Avatar
The MC is high on the firewall.
Thanks
Old 09-01-2011, 07:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Another thought, I came up against when putting all discs on my Nova, in the late '80's, some manufacturers came up with what they called a Quick Takeup MC, designed to work with brake systems where the pads didn't make full time contact with the rotor, they had a longer stroke to take up the slack before apply. It was to help with mileage requirements, cut drag. Any chance you have one?
Semper Fi
Old 09-01-2011, 07:56 PM
user151's Avatar
If three nuts were too much, how about trying two? Or one?
That might tell you how much to lengthen the rod.
How Much Pedal Travel redsdad Suspension - Brakes - Steering 5 08-29-2011 06:24 PM
Excessive brake pedal travel......... Trans Am Tony Suspension - Brakes - Steering 10 05-13-2007 08:07 PM
Pedal Travel Animal Suspension - Brakes - Steering 16 08-22-2006 08:22 AM
Brake Pedal Travel yooper Suspension - Brakes - Steering 3 04-23-2004 02:34 PM
Manual brake pedal travel jpd37 Suspension - Brakes - Steering 8 05-22-2003 01:17 AM
