Excessive oil consumption (sbc)? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2012, 11:09 PM
This is a fairly fresh .030" 406, there is no blow-by, plugs are good & clean, no leaks, but it'll go through about a quart in 150 miles, I'm running baffled VCs with PCV on one & a breather on the other, any ideas?
Old 10-25-2012, 11:26 PM
vinniekq2's Avatar
What weight oil? good oil pressure?It has to be going somewhere,there has to be a trail. recheck plugs.back of intake is a common leak.
no smoke at all?
Old 10-26-2012, 12:28 AM
No smoke at all, pipes are clean, no soot, intake rails are dry, the only sign i see is oil on the threads of plugs, wondering if its the rings, but there no blow-by what so ever, has me puzzled. VC gaskets are those blue rubber/tin units, its all dry around that area.
Old 10-26-2012, 02:39 AM
blwn31's Avatar
Intake rocker studs are an easy place to suck lots of oil. Ask me how I know, on second thought lets not. If everything else checks out, rings.
Keith
Old 10-26-2012, 09:09 AM
Not in any particular order :
valve guides
rocker studs
intake gskts
rings
index a couple plugs & check to see if top or bottom is darker
run a compression & leakdown test
this SHOULD[??] help you isolate your problem
dave
Old 10-27-2012, 10:38 AM
The heads are iron eagles with screw in studs, i'm really thinking rings at this point.
Old 10-28-2012, 12:42 PM
400 blocks if not preped correctly they will burn oil as the are preety weak block. Do aleak down test at TDC and see where your at.
Go over this link and check out the pics on page 3
Mike Lewis & other engine builders - Chevelle Tech
Old 10-28-2012, 05:37 PM
Never use forged "racing" pistons that use 1/16" top and second rings in engine that is driven daily. . The 1/16" rings are low tension rings to be used on low silicon forged pistons in high RPM racing engines. The 1/16" rings have poor oil control at low RPM. Always use forged pistons that use 5/64" top and second rings. Those type pistons set up at .002" - .0035" clearance and utilize oil return slots instead of return holes in the oil ring lands.
If one insist on using 1/16" low tension rings, a block plate should be used when honing the bores. The 1/16" low tension rings require perfectly round cylinder bores and the ends should not be file fitted. File fitting makes rings progressively egg shaped. Select the 1/16" low tension rings using a bore light and use only the rings from several sets that fit the bores as is. In drag racing engines using thin low tension rings, block filler such as "Hard Blok" should be considered.
Automakers today are using low tension metric rings in new cars to improve gas milage.
Old 10-28-2012, 06:09 PM
vinniekq2's Avatar
mouse,you set piston to wall clearance at 002-0035 for a forged piston?
Old 10-29-2012, 05:52 AM
Are you serious ?? I have built alot of street and strip engines over the years with 1/16 ring packs and never had any issues with oil control.
WTH are you talking about I have used file fit rings in just about every engine I have built with zero problems.
I am a believer in torque plate honing and using a good hone and the proper stones to do the job correctly. Alot of shops are using substandard hones to hone they just don't work.
I am careful on my choice of oil control ring anf their tension.
If you are having to fill a block your using the wrong block.
Where did you ever come up with this false imformation ???????
Old 10-29-2012, 07:46 AM
Low silicon forged pistons that use 5/64" top and second rings need .002" - .0035" clearance due to a more controlled expansion rate. They are made of 4032 or VMS-75 forged 11% silicon/aluminum alloy with 5/64" top and second rings. Speed Pro L2256F for example
High silicon forged racing pistons that use 1/16" top and second rings need .006"- .010" clearance due to their higher expansion rate. Made of 2618 forged 2% silicon/aluminium alloy with 1/16" top and second rings.
The 4032 or VMS-75 high 11% silicon aluminum forgings are more suitable for street and strip use whereas the 2618 2% silicon aluminum forgings are better for boosted and racing engines. If used in a daily driver, low silicon pistons that use 1/16" top and second will have problems with oil control at low RPM or when not at the proper operating temperature. .
Old 10-29-2012, 07:59 AM
engineczar's Avatar
Huh? Now I've heard everything.
BSE Racing Engines
Old 10-29-2012, 08:22 AM
I use alot of 2618 and 4032 material pistons and to date non of them required .002 clearance
Old 10-29-2012, 08:46 AM
You apparently have never used a bore light to fit the rings in the cylinders.
For winning racing engines, after the cylinders are finish honed with a block plate, then the rings should be select fitted using a bore light as they come out of the box. The ones that do not pass inspection in the bore should be put on the shelf and used later in daily driver engines. .
Old 10-29-2012, 08:47 AM
What is the part number of the rings in question?
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 05:40 AM
mysterious SBC oil consumption information Bonhorst Engine 4 01-23-2010 02:35 PM
Last question before SBC off to machine shop (oil consumption) y2k600f4 Engine 5 04-14-2009 01:05 PM
sbc oil consumption help needed jw4413nv Engine 5 05-13-2007 01:41 PM
Excessive oil under valve covers in SBC? TVR383 Engine 13 11-21-2005 01:48 AM
