Excursion project
Let me start off by saying i've never painted a whole car. The most i've done is a couple touch ups when I was in high school. I paint steel so I have a pretty good idea "how" to do it and the tools (compressor,sprayers,da, no booth). I'll try to learn as much as I can by trial and error.
I have a 2000 Excursion that isn't really in bad shape. It's Arizona Beige but I believe it was Maacod right before I bought it. The paint is flaking badly on the underside of the wheel wells. There are a couple really dull spots in the paint under the rear windows. Kinda like they were touched up and it didn't take. My plan for now is to two tone it like ford did on the later years from the factory. Maybe something in a dark green. I'm going to use filler to level up the paint chips and sand it from there. I would like to avoid thick paint lines from the tape. I've read good 3m tape will help with that. I've never really masked anything. What I know nothing about is paint. Everything in our shop get's Sherwin Williams primer and paint. I really don't want to base/ clear it. I have next to nothing invested in this truck and i'll be painting in a dusty shop so I plan on a little sanding. There are a few online stores that sell kits for around 70.00. Is it worth it to save a few bucks or should I just go to the local paint shop ? Please keep in mind i'm not cheap but this truck has 235,000 miles on it. Any input on this will be greatly appreciated. |
look at kirker single stage. I would only single stage if its NOT a metallic color. Also I would blow the area that is peeling with compress air to blow any paint off that isnt sticking.
A other idea would to prep it and have someone else paint it with a botth and more experience good luck |
I have blown the areas down with air and sanded the edges as much as possible. I'm starting to fill in the low spots now. I'll take a look at Kirker SS. I'd really like to do this project myself. I'm one of those guys who hates to have something done at a shop when I could do it and learn in the process. I'm thinking a dark green would match well with the beige.
There's not anything much BIGGER to learn on!!
Are you painting the top part or the bottom part? And as far as thick tape edges, that is based off of HOW MUCH paint you spray not tape you use. Clean, crisp edges is from the QUALITY of the tape.
| Re-named project | One Month Wonder | Introduce Yourself | 2 | 04-22-2009 08:54 AM |
| I'm Bored...How About A 1967 Pontiac GTO Project ??? | izzymiddleton | Hotrodders' Lounge | 9 | 03-07-2009 10:26 PM |
| Project planning | 580Z | Hotrodding Basics | 5 | 04-27-2005 03:20 PM |
| The SN65 Project Car - graphic design | SN65 | Body - Exterior | 0 | 03-21-2005 10:22 AM |
