exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 02:45 PM
exhaust
I just switch my 81 cutlass motor from a v6 to a 350 with a 262 lunati cam and short hooker headers and moroso heads would it be best do go with dual exhaust or a single pipe with a flowmaster?
Old 05-11-2011, 03:20 PM
DoubleVision's Avatar
We had duals installed on many cutlasses without issue.
Old 05-11-2011, 04:42 PM
Onefunponcho's Avatar
Its all up to your personal preference. Their is some performance to be gained by having the correct size of pipe. If you go single exhaust you would be best to have 2 1/2" or 3" pipe. If you run duals then 2 1/4" pipe would do dandy.
Old 05-11-2011, 05:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Moroso heads?
Anyway, even if it's a mild build, long tube headers would have been a better choice. Might mean a floor shifter would be needed, though.
If you have the funky crossmember, it's kind of hard to run duals w/o swapping the crossmember for one w/room for dual exhaust. Someone here may have a workaround for this, though.
Old 05-11-2011, 06:03 PM
In a 1980 cutlass that we swapped from a diesel to a 455 the transmission crossmember had a hump on both sides for dual exhaust. I cant promise that yours will be the same but ours was a double.
Old 05-11-2011, 06:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not sure either. I seem to remember a '81 Monte having the slanted one that was hard to work with, but doesn't mean that's what he has, but HERE'S one that'll work w/duals if his is the bad one.
Exhaust Chevy 84 Engine 1 11-01-2007 05:53 AM
Changing exhaust to intake and intake to exhaust? BillyJoe Engine 3 03-28-2006 07:29 AM
exhaust cut-out? 39chevy Electrical 7 09-21-2004 08:58 PM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 06:42 PM
exhaust cajunone99 Hotrodders' Lounge 1 03-03-2002 12:18 PM
