The old Stove Black seems to hold up fairly well & is cheap. They will need to be clean, sand or bead blasted for best results.
Ceramic coating would be best but, not cheap. |
Powder coating is not really meant for high heat situations like exhaust headers. That's why you have the problem you have. Chrome paint won't look good and will last about 10 minutes if that long once the engine is running. Ceramic coating is the ONLY way to go.
As an example, these headers were ceramic coated by Jet Hot in Phoenix and they cost me $500... but they're long tube with turnouts. Ram horns would be a lot less, probably about $200. Centerline HotRodsAndHemis.com "Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen |
I think there're a few old Threads on here about painting Intakes & Exhaust manifolds. Some work some don't.
You would have to check with a few Co.'s for coating prices. JetHot is one> http://www.jet-hot.com/ google will find others. One more I had saved>> http://www.headercoatings.com/ |
I know these are not Ram Horns but stock Chevy cast iron manifolds that have been ground smooth and then ceramic coated, by Affordable Power Coating in Phoenix Az and if I remember the coating was less than 100.00 like 90. It was worth it to have them ground smooth which was more than the coating
Centerline HotRodsAndHemis.com "Congress will eventually do the right thing, but first it must exhaust all other possibilities." - Ronald Reagan |
| Best Exhaust for a 305 | 85silverado | Engine | 14 | 03-28-2006 04:16 PM |
| Changing exhaust to intake and intake to exhaust? | BillyJoe | Engine | 3 | 03-28-2006 06:29 AM |
| Exhaust flow on side exhaust | ZeeksChopShop | Engine | 0 | 06-03-2004 05:42 PM |
| Hot exhaust | Chevy Guy | Engine | 1 | 08-14-2003 09:51 PM |
| exhaust? | 74huggerorange | Engine | 1 | 03-26-2003 10:57 AM |
