exhaust ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2002, 12:14 AM
mlr mlr is offline
Post exhaust ?
I am trying to find a exhaust system for my car. I orginally wanted a flowmaster exhaust but when I looked into it they were extremely expensive. I looked at a J.C. Whitney catalog and found a full exhaust for half the price. does the name really matter. also where is a good place to find a exhaust system for a 79 camaro 305. i tried summit but they don't have it and it has to be mailed to me.
Old 12-02-2002, 02:52 AM
roys63's Avatar
Post
Have it Made at Exhaust shop?
Old 12-02-2002, 03:29 AM
Tazz
Cool
Roys63 is right.. The exhaust shop is your best bet unless of course you have a full service lift at home. Cralling on your back and aligning the exhaust correctly is a pain without a lift. So have it made and installed by a shop.
Todd
Old 12-02-2002, 10:34 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
The better brands will use better components. They will usually be aluminized and use mandrel bending. It looks much better, and the madrel bends help performance. If it is a daily driven beater go cheap. If it is something you want to keep and you are spending alot on the rest of the car, dont cheap out on the exhaust.
I would buy the mufflers and have an exhaust shop fab up aluminized pipes. I had mine done in 3 inch duals for $150 installed, but I supplied the mufflers and turndowns.
chris
Old 12-02-2002, 01:11 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Post
Make sure it's mandrel bent, and if it's a trusted name (flomaster, borla, summit, etc.), it should work well.
I have a '93 Saturn SC2 (the SOHC Saturns are great for grocery runs but not much else) and the stock exhaust is a peashooter pipe as I call it, and would it be better to go 2 inch, 2.25 inch, or 2.5 inch exhaust? I don't want a coffee can exhaust if you're wondering.
[ December 02, 2002: Message edited by: ChevelleSS_LS6 ]</p>
