Exhaust Band clamps vs. Welding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2008, 01:27 PM
I'm currently purchasing 304L Stainless Steel tubing to go with my muffler and cat. I do not have the capability of welding 304L Stainless Steel.
I was curious if the clamps below are acceptable, or am I better off taking the system somewhere and getting it welded? It would be nice to be able to replace the muffler or cat without cutting, but if it's the better of the two, which I assume it is I'll do it.
Band Clamp
Band clamp 2
Any info or other advice would be great!
Ryan
Old 02-07-2008, 03:09 PM
FASTFORD's Avatar
I used band clamps on my exhaust system. i like them,work good.
Old 02-07-2008, 04:30 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Those are good clamps and will work just fine...go for it!
Old 02-07-2008, 10:04 PM
How perfect do the ends have to match up with those clamps?
Old 02-08-2008, 08:01 AM
I have no idea, I assume as long as it's the same size tubing and they are not burred up or uneven they should be ok?
I was looking at V-Band clamps, but they require welding.
If there are other manufacture's band clamps that may be better than others I open for suggestions.
Old 02-08-2008, 08:33 AM
The clamps you show, allow the two exhaust pipes to slip together. The seal will be better than the crush style. The band clamps are stainless and look great. One added plus factor is later on you may want to make changes and thats just a wrench away from making any change. Go with the band clamps. One last thought on welding - how good is the installer? Crappy welds will take everything away from a neet install. TF
Old 02-08-2008, 11:19 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The stainless clamps I recall using in the heavy truck fleet, were ones that came with those same ends. but they came as a flat sheet without the step. Because the heavy end pieces HAD the step machined into them, the flat band would actually make it's own step as you tightened it. It stretched the metal for a super tight seal to any irregularities.
Old 02-08-2008, 08:43 PM
Here are some more pics of the clamp, looks like they might be ok after all:
Band clamp 1
Band clamp 2
Band clamp 3
Thanks for the adivce guys. If I decide to find a welder, I will ask to see some samples prior to letting them do the work. I think I might have to get the reducer welded.
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 07:04 PM
new breakthrough: spinner exhaust tips Jon Hotrodders' Lounge 24 10-18-2005 12:21 AM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 03:30 AM
Welding On Exhaust rbfpezcore General Rodding Tech 51 08-17-2005 08:21 AM
Exhaust welding? 87442lover Engine 8 05-02-2004 09:19 PM
