Exhaust Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2007, 01:01 PM
Exhaust Clearance
I have a Model A with SBC and Sanderson Cast Manifolds that dump straight down. Tha header pipe is about 1 inch from the aluminum fuel line that is mounted inside the frame rail. Is this too close? any suggestions. Thanks
Old 05-23-2007, 02:15 PM
Unfortunately, with a SBC in a 1928 to 1934 Ford chassis ... that is common. My 32 right side exhaust is about 1 and 1/2 inches off the frame rail.
I always try to have the exhaust pipe coated with a thermal heat barrier. Like Jet Hot ... It really helps keep the heat down around the pipe and it improves the appearance too.
Old 05-23-2007, 11:02 PM
techinspector1's Avatar
Wiki Edits: 326
Make up a thermal barrier from 2 sheets of aluminum cut to the size they need to be. Use washers, bolts and lock nuts (not the ones with the plastic insert) in several locations between the 2 to make a sandwich about 1/2" to 3/4" thick and mount it between the pipe and line. The plate next to the pipe will get hot as the hubs of hell, but the air between the two plates will prevent transfer of the heat to the plate next to the line, particularly if you mount it so that air passes through when you are moving. Problem solved. For cheap.
« 71 nova | welding »
Exhaust System Sizing leejoy Engine 9 10-04-2006 07:38 PM
Exhaust Cross Connections Other Than X or H? JohnTN Engine 2 06-23-2006 06:04 AM
Exhaust formulas vs. computer programs Mean Dean Introduce Yourself 1 07-13-2004 12:26 PM
lump lump factor oldsgeek Engine 15 06-05-2004 12:46 PM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 05:42 PM
