exhaust collector length ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2008, 07:30 PM
Vortech 4.3's Avatar
jack of all trades
i have seen how collector length effects power. but what if the whole exhaust system is the same size as the collector ? thanx
Old 04-28-2008, 10:52 PM
I asked the same question in 1969, and never got an answer other than "you can't do that," or something along that line.
See if you can dig up David Vizard's article (actually an excerpt from one of his books that was published in one of the car magazines) about low-noise low-restriction exhaust systems and the use of a terminator box to mimic an open-ended collector.
The basic idea is to work out your ideal collector length, then use a big empty volume at the end of the collector to make it think it's dumping into atmospheric pressure air, but still containing the exhaust gas and routing it into a low-restriction muffler system. He said a big Flowmaster muffler or an empty muffler case would do, as long as each side had one that had 10 times the volume of one cylinder for a V-8 engine.
Old 04-30-2008, 09:09 PM
jack of all trades
thanx. i'm going with 2 1/2" all the way back. and let the cards fall where they may.
longer exhaust duration ? 383silverado Engine 5 05-23-2007 07:24 AM
exhaust crossover ljjjrome Engine 8 04-03-2007 12:22 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Exhaust formulas vs. computer programs Mean Dean Introduce Yourself 1 07-13-2004 12:26 PM
Exhaust Manifold Leak???!!!?! ponybuster Engine 4 09-17-2003 02:41 PM
