Exhaust Cross Connections Other Than X or H? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2006, 05:17 PM
Is there any reduction in noise or drone by installing a interconnecting pipe between true duel exhausts that is neither an H or X, but more like a U?
There is no room in my 1939 Olds chasis to use an H or X in the true duel setup (2.25 inch pipes through IMCO passenger mufflers). But the Olds V8 engine originally had a crossover pipe from the drivers-side exhaust manifold to the passenger side exhaust manifold. The inlet to the passenger side was blocked when installing the duel exhaust and the crossover pipe was tossed.
I am trying to reduce the drone at about 1500 rpm and was considering asking the muffler shop to install a crossover pipe from the drivers side below the exhaust manifold to the old inlet to the passenger side exhaust manifold.
Or, just weld a crossover pipe between the two exhausts pipes-- the corssover would go under the shallow part of the oil pan where the original pipe ran. More like a 2 foot "U" pipe.
Anyone have have experience like this?
John
Old 06-23-2006, 05:08 AM
Hippie's Avatar
Last journal entry: HEI comparison.
It's certainly worth a try and I don't see that it could cause any harm if it doesn't help other than lighten your wallet a little.
Old 06-23-2006, 06:04 AM
astroracer's Avatar
So you'll have a "U" shaped "H" Pipe...
Mark
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
small tubes added to headers for more power?.... sc2dave Engine 10 03-07-2005 06:35 PM
Exhaust formulas vs. computer programs Mean Dean Introduce Yourself 1 07-13-2004 12:26 PM
Cross Flow Exhaust.............. bg Engine 6 01-21-2004 07:09 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
