exhaust cut-outs question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2005, 08:58 PM
New Member
i found only one exhaust cut-outs that use a control cable to remotely open it. the trouble is that it's only 2" and my exhaust pipe are 2"
i am worry about performance reduction ???
the other one that have a size of 2 are
electrical:high $$$
with wing nuts:you must crawl under the cars to remove them
Old 01-15-2005, 09:54 PM
akm akm is offline
i looked and couldn't find a 2 1/2" manual cut-out, BUT i did find an electric one for about $150 each, which should save you about $200
http://www.pfyc.com/store/merchant.m...ory_Code=C6EXH
Old 01-18-2005, 09:49 AM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
not to sound like a complete idiot, but what is the purpose of such a device?
Old 01-18-2005, 01:17 PM
Siggy_Freud's Avatar
The cutouts allow you to go open headers with minimal modifications to the exhaust.
Drive your car to the track with the full exhaust, and then on the line, switch over to open headers with the pull of a cable or push of a botton.
If you are going to do it, go with the electrical. I've seen too many problems with the cable activated ones not sealing all the way.
Bringing history and technology together.
Old 01-18-2005, 02:22 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
So do you have 2 exhaust systems, one with a straight pipes and one with muffled pipes? And then there is a valve that seals the flow to the muffled pipes and opens it to the open ones??
That's cool
Mike
Old 01-18-2005, 02:41 PM
The cutouts are usually right after the collectors. When they are open its like running open headers with a small extension off the headers. With them closed, the exhaust gasses continue on their normal route through the mufflers.
Old 01-25-2005, 06:00 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
This has been discussed before on this site.
One of these postings will give you the info your looking for.
http://hotrodders.com/search.php?s=&...by=&sortorder=
Luv the smell of NITRO in the morning.
Old 01-26-2005, 06:58 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
C'mon, get under the car and open them up you pansy. Just Kidding.
I bought the kind that you have to open yourself, I couldn't justify the expense of the eclectics. And I wouldn't want it reducing to a 2" diameter from a 2.5".
Hey guys I'm going to run my cut outs right after my X pipe, I bet it sounds cool.
Old 01-27-2005, 04:01 PM
Tazz
sounds just like running without a muffler...
Not sure if its worth the cost....run Flow Master mufflers and forget the cutouts...I have had them and they can be a problem sealing then your car sounds like it has and exhaust leak all the time.....and thats not cool!
Tazz
Rat Rods Rule!
