Exhaust drone - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 09:29 PM
57halfton's Avatar
Exhaust drone
Awhile back I bought new factory side exhaust for my Corvette and took the old side pipe chambered mufflers that were on it and put UNDER my pickup with the turn downs ending just ahead of the rearend. I recently put a new bed floor in the bed and the drone got worst inside the cab. If I use tail pipes out the side in front of the rear wheels or out the back to the bumper will this reduce the drone inside the cab ?
Old 02-02-2012, 09:47 PM
bigblockragtop's Avatar
I am not sure if I can remember but my brother with his roadrunner had a horrible droan and his exhaust exited the back of the car. He found an article that said putting a weight on the mufflers will stop it and it worked, if interested I can find out exactly what he did. Another thought an old time drag racer once told me be careful with exhaust exiting in front of the rear tires if the engine blows and oil dumps out of the exhaust it will get you sideways in a hurry.
Old 02-02-2012, 10:00 PM
nine4gmc's Avatar
pipes will help drastically, if your muffler is oval you can rotate it vertical and that helps a lot with drone also.
Old 02-03-2012, 01:08 PM
You probably know better than to do this but don't point your pipes towards the road surface or the floor of the vehicle. A balance pipe; over axle pipes or a single chamber/ short glasspack 'resonator' will kill some drone
Old 02-03-2012, 01:12 PM
techinspector1's Avatar
Wiki Edits: 326
Yes........
Old 02-03-2012, 08:07 PM
Bonneville462's Avatar
I get a horrible drone when I use a H pipe or turn downs....
You might want to look into Porter mufflers..
http://www.portermufflers.com/
Old 02-04-2012, 08:27 AM
SSedan64's Avatar
Stop the Drone
From an older Thread >> http://www.camaro5.com/forums/showthread.php?t=102075: Helmholtz Chambers added to existing exhaust.
Old 10-28-2012, 03:11 PM
Porter Mufflers
Update, I ended up using Magna Flow mufflers they have a superb sound!
I did it. Eliminated the 2000 rpm exhaust drone Ripped Engine 14 01-14-2015 03:57 PM
are you tired of engine drone? stealthninja Hotrodders' Lounge 2 01-04-2012 05:14 PM
Exhaust Drone - Noise Problem jpd37 Engine 22 04-02-2008 06:47 AM
Damping Exhaust Drone/Resonance JohnTN Hotrodding Basics 18 01-16-2008 10:45 AM
Advice on setting up a low drone street exhaust Dubz Engine 4 10-20-2004 11:11 PM
