Exhaust dumping minimum length - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 10:05 PM
BMM BMM is offline
Hey. Would running seperate pipes (1 for each cylinder), about 2 feet long off the head cause major backfiring issues? Any other ill affects, other than the noise?
thank you.
Old 07-17-2008, 12:52 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Originally Posted by BMM
Any other ill affects, other than the noise?.....
Hearing loss. Huh?
To answer the question, maybe. If the backfire is on decel, yes. If the engine is healthy, no.
Old 07-17-2008, 11:42 AM
thank you.
Not a very efficient set up for engines thzt don't spend a lot of time above 6000 RPM. Headers into a collector will make more power.
Bogie
Old 07-17-2008, 04:08 PM
Last journal entry: frame build
If you think carbon monoxide poisoning isn't a problem then no. Airflow around most cars will put the exhaust right in the cockpit if it is ahead of the doors.
Old 07-17-2008, 10:29 PM
BMM BMM is offline
Aye, damn it. I was thinking it might look really cool to run the exhaust straight out my hood on my Cutlass, seeing as how I can't afford to drive it more than a day a week as it is.
Time for exhaust change cutsupreme Engine 17 08-02-2007 06:42 PM
zero-loss exhaust system? fiscus Engine 5 02-26-2007 10:45 PM
Cutlass exhaust manifolds ChrisMiddleron Engine 9 09-27-2005 03:08 PM
Exhaust Damage Paint Riverman Body - Exterior 1 09-10-2005 06:40 PM
Exhaust location advice needed. Pic enclosed hemi43 Engine 3 06-29-2005 04:06 PM
