Exhaust gas analyzer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2009, 09:05 AM
blue54's Avatar
Anybody out there used a Gunson analyzer and if so what do you think? I'm looking at used analyzers and at $219.00 new maybe it is the way to go??
Old 06-08-2009, 11:44 PM
001mustang's Avatar
You are using analyzer for feeding data to on car computer?
Old 06-08-2009, 11:54 PM
blue54's Avatar
No. Just to set up carbs
Old 06-08-2009, 11:59 PM
blue54's Avatar
I figured that it would give me a good starting point.
Old 06-09-2009, 12:22 AM
001mustang's Avatar
I know of several cases where analyzers don't produce accurate real time data so I choose not to install analyzers.
I personally read the plugs because they don't lie. I read plugs for every mode; idle, cruise, 2BBL acceleration and WOT. You can tune a carb in pretty good with plug readings. It is not too hard, once your carb is tuned you can forget about it. I set my idle lean so plug is white. Cool thing is a grey plug will change back to white if you run it lean; so you don't have to use new plugs for every test.
If you want to go to the next level of tuning then a G-Force type computer would be nice. Just plug into lighter socket. They provide accurate acceleration data so you can tune your car very precisely.
I did it. Eliminated the 2000 rpm exhaust drone Ripped Engine 14 01-14-2015 02:57 PM
Gas Thieves!!!! Weimer Hotrodders' Lounge 28 03-03-2010 02:46 PM
Will open headers actually warp the valves? 70bird Engine 19 06-28-2005 03:03 PM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 05:42 PM
exhaust smells like gas toddtheodd Engine 10 05-14-2004 02:58 PM
