Glasspacks with a big cam sounds like crap. My friends duster with packs on it and a 509 cam sounds like a cowboys pickup truck. its semi cool at idle, but at 2K rpm, it just gets LOUD, everytime I drive that car I have to look around to see if there are cops, they'd think I was screwing around when I"m just driving.
Glasspacks are just great on a stockish type vehicle, they make it sound tough when there is really nothing tough about it. It's all about how you set the exhaust up. Glasspacks rule. |
my choice for my 74 nova ss was flowmaster race mufflers they are small compact
deep throaty sounding mufflers it has a mild 350 and these mufflers give the sound i was after and they are almost as loud as a glasspack when you romp on it just not white trash.speaking of white trash i have some long glass packs on my elky cause to me this car screams white trash and the sound fits |
No one has mentioned that the old style glass packs actually flow less than most stock oem mufflers. These old gasket packs just make noise. The old style glass pack use bumps on the walls of the tube to make tubulence to muffle sound which doesn't muffle sound very well but make a huge restriction.
The new style glass packs flow almost like a straight though pipe. The new style use a perforated tube (lots of small holes) on the inner walls. Dynomax makes a good one. I like them for resonators or for a little extra sound control before or after the main muffler. FlowMasters flow fairly well but not as good as a Dynomax Super Turbo which makes about 10 times less exhaust noise (almost oem quiet). The sign of a good muffler is it's flow to noise ratio which makes a flowmaster a low quality muffler. Hooker Aero-chambers flow really good (50% more than a flow master) and are about 5 times quieter than a flow master. |
The only one of my toys with mufflers on it, is flat black, has a gear drive, a four speed, and glass packs. They aren't the best flowing mufflers, but they have that nostalgic hot rod sound. As far as mature hotrodders, isn't that kind of an oxymoron. We're still playing with toy cars, we just don't push them around the kitchen floor anymore. That is unless you have a big kitchen and an understanding wife.
Kevin |
Hmmm
glasspack
Most of the older hot rodders like these for the old fashion low rumble. My friends and I are all 17 to 18 and everyone of us have either a thrust glass pack or cherry bomb on our trucks. I drive an 86 Chevy s10 2.8 liter v6 and it gives it a real nice low rawr and the famous pop!
glasspack
When I got my first car that I could call my own ,a 49 Ford drop top I could not wait to get a good (read loud!)exhaust system on it . So I did what my buddies did to speed the process up,I bought new glasspacks and took them home and built a big fire in the back yard and poured some used motor oil in the mufflers and put them in the fire for a couple of hours to burn the fiberglass out.After they cooled enough to handle put them on car.Boy to a 17 year old kid those things were the coolest sounding pipes around and to the cops they were the loudest thing around cuz I got two loud muffler tickets the first weekend that they were on the car!! I had them on less than two months I had to put some stock mufflers back on it because I got tired of being stopped by the cops and the hassle over them from my mom.
Kenny Lost your job yet? Keep buying foreign. |
The problem with flowmasters is they are actually a poor flowing muffler, just have a good marketing dept.I have seen many tests showing a Hooker aerochamber or magna flow mufflers out horse powering them by up to 50 hp on 500 hp engines.
Back to the inner pipe. The perforations make the difference as to whether the muffler has low or high restriction. High quality glass packs will have the perforations punched in the inner pipe which would start as a flat piece to be rolled into a tube. The perforations usually are contained in the base of a outward facing dimple. This configuration allows energy to easily expand into the space between the tubes without adding anymore resistance to flow than that offered by a straight piece of pipe. Cheap glass packs are made much the same except that the inner pipe starts as a tube and is slash cut with a saw to open the perforations. This process leaves rough exposed edges and burrs that project into the exhaust stream causing resistance to flow. In many cases mufflers made this way have no better flow than a stock muffler. Glass packs are sold in varying diameters and lengths, this can be used to tune the sound where larger diameters and or longer lengths favor low mellow tones, smaller diameters and or shorter lengths favor higher sharper tones. So called turbo mufflers are very loud when used on a non turbo engine, they depend upon a turbo being upstream of the muffler to remove much of the sound. If you're putting glass packs or turbo mufflers on an engine with catalytic converters you can expect either to be much quieter as a converter soaks up quite a lot of noise. The exhaust note with converters is also higher and raspier as converters tend to soak up the low frequencies, that glass packs and turbo mufflers usually pass, but now the low tones are gone before the sound even gets to the muffler. This is the situation with my 350 S-15, having to be a smog legal conversion, it's running dual cats thru dual glass packs with an H pipe just behind the header's collector. It originally had a single 3 inch cat into a 3 inch Flow Master series 80 that emptied from a 3 inch side dump ahead of the right rear tire. This system never worked the way I though it should and was ungodly loud in the cab. The present duals empty out behind, so cab noise is significantly reduced. The engine gets (documented) better fuel economy by almost 4 mpg and has more available power. Plus, even with fuel injection, it raps the pipes like an old fashion rod, which surprised me given the injection and converters. Bogie |
Yeap...muscle car tunes baby!
Back in high school it was the sound of mopars vanishing into the sunset;,,,yeap.
| windshields | bill66di | Body - Exterior | 15 | 07-31-2004 07:31 AM |
| door glass | fred56 | Interior | 4 | 10-22-2003 09:40 PM |
| Are Glass packs legal in Oklahoma | Ray102386 | General Rodding Tech | 6 | 07-24-2003 05:14 AM |
| Glass packs | dannimo | Engine | 4 | 06-19-2003 02:11 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
