Exhaust leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 06:12 PM
Exhaust leak
This maybe is a dumb question but i'm trying to put a band aid on my exhaust until winter. I will replace the whole system this winter. The two sliding connector or what every you call it where the header and the exhaust pipe meets is wavy. I used the dead aluminum gasgets and tighten the three bolts up but the sliding contectors are so wavy that is leaves a gap between the header and exhaust. This maybe dumb but is there any type of caulk that I can fill in the gap to get me by for a short while. I get some exhaust in the cab because of this.
Thanks
Marcus
Old 08-17-2006, 06:34 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Sounds like you could just use a few gaskets stacked up instead of just one to (band aid) The situation.
Old 08-17-2006, 06:51 PM
you could try high temp silicone if there is no oxygen sensor in the system or muffler cement should work well also.
Raw oil through the exhaust? TVR383 Engine 16 11-02-2005 04:24 PM
new breakthrough: spinner exhaust tips Jon Hotrodders' Lounge 24 10-17-2005 11:21 PM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
lump lump factor oldsgeek Engine 15 06-05-2004 12:46 PM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 05:42 PM
