Exhaust leak..will this fix it??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2006, 05:14 PM
Z-Money Pit's Avatar
I have an exhaust leak at the collector gasket on my Ford 302 engine. I made up my own "H-Pipe" for the exhaust and I think I am a hair off on having it line up with the driver side header. I can bolt up the collector fine but I have a small leak at the top side of the collector when I use stock style collector gaskets. I looked in a few local auto parts stores today but I could not find any of the dead soft aluminum gaskets. I found a set of thick Spectre gaskets (some sort of graphite-like material) that I guess I will install. My question is this, can I double up on these gaskets on the left side to prevent a possible leak. Will doubling up lead to a leak between the two gaskets where they press against each other?
Thanks for your ideas.
Old 09-27-2006, 06:38 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I have heard of people doubling up on the copper type collector gaskets with good results. I have never tried it myself but seems like your best bet.
Old 09-27-2006, 08:20 PM
Problem solved!! I doubled up on the gasket and the leak is gone.
Old 09-28-2006, 06:03 AM
Technical Support Barry Grant
Make sure to re-tighten them a few times after it goes through some heat cycles. Also, keep in mind with the double gasket it will be more prone to blowing out so you'll want to check them often.
Exhaust location advice needed. Pic enclosed hemi43 Engine 3 06-29-2005 04:06 PM
Turbo`s and Super`s for the intake but what of the exhaust...? Bumpstick Engine 4 05-15-2005 06:44 PM
Exhaust, plug or head gasket leak? frankenvette Engine 13 04-24-2005 04:37 AM
anti-freeze leak cabrio Engine 5 06-11-2003 05:31 PM
How To Fix A Leak F-1Rodder Engine 4 01-23-2003 09:37 AM
