exhaust manifold and oil dipstick in each others ways - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2005, 07:52 PM
montea's Avatar
tryn to learn
i got a 79 SBC 350 i just built up and its pretty much ready to be put into my car. just went to install the ehxaust manifolds and the drivers side one wont go on because the oil dipstick is in the way, i tried to bend it out of the way but no luck and ended up bending it enough the dipstick wont go through it anymore. the manifold is right inline with the oil dipstick hole in the block.
do you guy have any suggestions of what i should do here?
could get differnt manifolds or install headers but then the exhaust needs to be redone and i just put on this dual exhaust.
Old 06-14-2005, 09:04 PM
66 T-Bird's Avatar
~Low Budget Baby~
locar makes one that is like stainless steel line that bends i think
Old 06-14-2005, 09:17 PM
poncho62's Avatar
Wiki Edits: 5
You need the oil pan that has the dipstick in it, that clears your manifolds. I believe the dipstick ends up on the passenger side. ....OR
Might be time to invest in a set of headers....they will clear. The "G" body exhaust manifolds suck anyways.
Old 06-14-2005, 10:25 PM
montea's Avatar
tryn to learn
ya, i got a set of brand new headers for it too but i dont have the $700 to get the rest of the exhaust this year. i just want this car on the road, im going onto the 3rd year of working on this car now and it hasnt goten me anywhere, set me back about 8+ grand and doesnt show 2
that lokar dipstick is $70! OUCH
Old 06-14-2005, 10:35 PM
montea's Avatar
tryn to learn
what i just did with the stock dip stick is remove the tube and mark down on the stick with a hack saw, when the dip stick is in all the way normally, and i marked it so i can use my finger nail in the groove and push down untill my nail hits the block. im sure it will work but i will have to remove the stick and keep it under the hood, if i leave it in the block it might hit the crank since it goes down farther.
Old 06-15-2005, 07:52 AM
MI2600's Avatar
Member# 3287
The manifolds were made for passenger side sticks. I had the same problem one time and used an old ram's horn and a piece of flex tube just to get it back on the road. Not pretty, not racing, but it worked.
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
"Stay away from fram oil filters" bullheimer Engine 27 05-16-2005 09:31 PM
Water in Oil? Echofive Engine 19 12-09-2004 05:44 AM
Can oil leak out of an intake manifold? leastbay Engine 11 08-12-2004 02:55 PM
oil leak when adjusting timing?? Trav Engine 14 11-15-2003 11:55 AM
