Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Exhaust Manifolds
Old 01-30-2012, 06:53 PM
Ossie Ossie is offline
Exhaust Manifolds
I would like to use exhaust manifolds that allow the plug wires to route across the valve covers rather than routing under the manifolds between the pipes and the block. The vehicle is a 1980 GMC Cabellero (same as El Camino)and the engine will be a 350ci. Any ideas on what will fit?
Has anyone used the distributor cap/ plug wire arrangement that outs the no.1 and no.8 wires close to the firewall/bulkhead/dash support? This arrangement with the standard firng order keeps the wires from crossing and it may look better.
