-   -   Exhaust Manifolds (http://www.hotrodders.com/forum/exhaust-manifolds-213638.html)
Ossie 01-30-2012 06:53 PM
Exhaust Manifolds
I would like to use exhaust manifolds that allow the plug wires to route across the valve covers rather than routing under the manifolds between the pipes and the block. The vehicle is a 1980 GMC Cabellero (same as El Camino)and the engine will be a 350ci. Any ideas on what will fit?
Has anyone used the distributor cap/ plug wire arrangement that outs the no.1 and no.8 wires close to the firewall/bulkhead/dash support? This arrangement with the standard firng order keeps the wires from crossing and it may look better.
vncruiser 02-04-2012 01:59 AM
There is a modified cap available through most speed shop catalogs. As for exhaust manifolds, 2nd gen Camaros and 68-72 Chevelle manifolds will allow running the plug wires how you want them, however, I don't believe they are workable on that chassis.
Reid :pain:
1996thunderchicken 02-04-2012 02:48 AM
Those manifolds will work because its about the same chassi as a abody or g body I used the same ones on an 86 camaro
