-   -   Exhaust manifolds (http://www.hotrodders.com/forum/exhaust-manifolds-6867.html)
tom_scott 03-02-2003 03:51 PM
Exhaust manifolds
I just completed my swap in my 82 silverado. I took out the 305 and dropped in an 87-89 350. The intake manifold did not bolt up to the FI heads since this was a TBI 350, so I had them drilled out to make them work with the old intake. My problem is the exhaust manifolds. I left them in the truck and stabbed the motor between them. However, my problem is I cant get them to bolt up. Are the bolt holes a little bit off. I have one bolt started but I cant get anymore. When I look to see if it lines up, it looks close but just a little off.
Anyone know if the 82 manifolds will bolt to a newer 350. Any help is sure appreciated....Thanks.
This is the first time I have done an engine swap...im sure getting an education.
1BAD80 03-02-2003 04:00 PM
I cant tell you if they fit or not, but if you have the old gaskets from both motors, overlay both of them to each other and you will see any differance. LOL
NorthStar 03-02-2003 04:08 PM
Theyre probably warped thats pretty common.
V8 S-10 03-02-2003 04:39 PM
I agree that they've got hot and warped :( You might be able to drill the holes in the manifold out a little bit and get them to go on or make a trip the the junk yard to get some replacements.
BOBCRMAN@aol.com 03-02-2003 04:56 PM
it is very common for these manifolds to be warped, enuff that some auto parts stores sell a "spreader kit" that spreads the ends away from the middle so you can start the bolts, these look like the old coil spring boosters that were marketed for years. also if the manifolds are that far out they usually aren't flat either, you will have to have them milled flat or you will have constant problems with leaks, i get a lot of these from motor homes and heavy trucks.
tom_scott 03-02-2003 05:27 PM
Thanks everyone for your replys....I bet you guys are right on with them being warped. Think I'll solve this problem with headers. Once again, thanks.
limey 03-11-2003 08:07 AM
that happens all the time. they make little spreader that thats what you need http://buy.snapon.com/catalog/pro_det.asp?P65=yes&qt=1&tool=all&catItem=true&INV _ONHAND=&FREIGHT=&qty=1&Item_id=10798&PartNo=YA130 0&Price=23.00&ListPrice=23.00&FORMNAME=3&Des c=Jack %2C+Manifold&SUB_Cat_ID=1467220&SUB_Cat_NAME=Expan ders%2FCutters%2FSpecialty+Tools&Cat_ID=1467219&Ca t_NAME=Exhaust&group_id=1343&group_NAME=Specialty+ Tools&store=snapon-store&dir=c atalog
well you have to copy and past the thing its to long
[ March 11, 2003: Message edited by: limey ]
[ March 11, 2003: Message edited by: limey ]</p>
KULTULZ 03-11-2003 08:50 AM
-Chevrolet {{snicker}} Exhaust Manifold Spreader-
MI2600 03-11-2003 04:42 PM
KULTULZ when I clicked on your reply I expected to see a big hammer! Where do you find this stuff?
