Exhaust manifolds glowing red.... TPI 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2011, 01:05 AM
goldenbullet44's Avatar
User that registered
my cousin has a 1987 z28 camaro with the 350 tpi in it. Well it runs doggy and has no power at all, it also overheats really badly. We replaced the water pump radiator spark plugs wire cap rotor took it out for a spin well it didn't have power what so ever.... We pulled over popped the hood and the exhaust manifolds were glowing cherry red we called up my friend to come tow it decided driving it at that point in time was not an option unless we wanted to make things worse then they already are...
What would you guys think the problem is with this car?
We are thinking about taking the heads off replacing the head gaskets check the pistons and stuff make sure we didn't mess anything up, thinking about converting it to carburetor...
Old 08-24-2011, 01:19 AM
Overdriv's Avatar
It is extremely lean or extremely rich. Both will make the exhaust manifolds glow red. Since you say it is overheating also, I'd guess it to be very lean.
Check your fuel pressures and make sure the timing is correct.
Old 08-24-2011, 01:36 AM
You better check your timing. If it is low on power and glowing the manifolds it is probably retarded on timing.
Old 08-24-2011, 05:48 AM
Richiehd's Avatar
JS-70
New motor? Did you adjust the valves too tight? I saw a guy one time adjust his valves like he had hydraulic lifters but they were solids. Exhaust glowed red!
Old 08-24-2011, 07:37 AM
Frisco's Avatar
Glad To Be Here
Lack of power and glowing exhaust is almost always caused by the timing being retarded. Check/set the timing.
The next possible cause would be a major vacuum leak causing an extreme lean condition. Check that ALL vacuum lines from the carb, TPI (this is what you say it has), intake manifold, etc. are connected at both ends and are in good condition.
Old 08-24-2011, 07:45 AM
glowing exhaust is caused by gas being burnt after the exhaust valve.
most cases it is caused by retarded ignition timing and/or a rich mixture.
Old 08-24-2011, 10:14 AM
T-bucket23's Avatar
Wiki Edits: 26
You may also want to make sure the exhaust is not restricted by a bad cat or something else.
Late ignition timing or a lean condition are the most common causes.
Chet
Old 08-24-2011, 01:03 PM
If you timed it with the vacuum line still on the distributor this can cause this problem. I seen guys that set total timing by reving the engine that forget to remove the vacuum line and cherry red headers everytime.
Old 08-24-2011, 01:25 PM
check out number 7
http://racingarticles.com/article_racing-56.html
Lt1 exhaust manifolds glowing red and hesitation and missing only when warmed up . Davi☠Rotten Engine 16 10-19-2016 09:21 PM
glowing exhaust 97Z28 Engine 7 08-06-2006 12:25 PM
Glowing Manifolds. Lean Condition? Chevy21 Engine 1 04-30-2006 11:10 PM
glowing red hot manifolds TeNn Engine 12 05-31-2005 12:16 PM
2 Exhaust Pipes Glowing Red Hot (Part 3 !) white66coupe Engine 12 06-14-2003 08:07 AM
