Exhaust manifolds or headers for 1952 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2011, 09:35 AM
Last journal entry: 1952 Chevy Street Rod Truck Build
Having a problem with the exhaust manifold on my '52 Chevy truck I'm working on. Has a mustang rack and pinion front end, 350 Chevy engine. I've tried 3 different sets of headers and several exhaust manifolds. On the drivers side the steering hook up is in the way. On the passenger side the lower control arm is in the way. I used the Speedway Mustang front kit. I've tried ram horns and several other set of Chevy manifolds but haven't found any thing that works. Any suggestion would be great. Thanks NickO.
Old 02-02-2011, 10:09 AM
jeffery wells's Avatar
to be honest, i cant really picture the set up in my head so a picture wold be great, but from what you have posted, i would say you might have to get a weld up header kit from jegs, and bend the pipe yourself, would give you a custom look and header performance, not to mention you can make it fit and combination of applications you can throw it at. (1800-345-4545)[/B]
Old 02-02-2011, 10:19 AM
Thanks for your reply.
Old 02-02-2011, 11:12 AM
Have you called Speedway? The steering column shaft could be moved. In actuallity it shouldn't even be installed until after the motor and exhaust is in.
Old 02-02-2011, 11:17 AM
dinger's Avatar
And you tried the hugger headers? Something isn't right here, I've a few buddies with the same era Chevy, they all get by with huggers or shorties.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-02-2011, 05:32 PM
41'srfun's Avatar
Last journal entry: 41' finally has paint on it
I have a 54 Chevy pickup with a Mustang II and 350 engine with stock exhaust manifolds from a 70's model engine. I used two steering u-joints to help the steering shaft clear my exhaust manifolds and have plenty of room for the exhaust that way. I used a steering column from a 87 S-15 Blazer. You may have to offset your steering column a little to get the right angle for the shaft to clear the manifolds or headers.
Old 02-03-2011, 08:09 AM
1971BB427's Avatar
Any chance you couls use fenderwell headers? Patriot makes the "fat fender chevy" headers that are quite reasonable and should clear anything. I used them on my Austin gasser, but I installed the engine with the headers on, so I built the steering around my engine and header install.
Old 02-04-2011, 05:43 PM
any route you decide to take, just remember to give them some wiggle room, unless you'r using solid mounts, just a little something i know i would be beating myself for if i didn't think of before hand.
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 11:21 AM
Chevy 4.3 V-6 exhaust manifolds speedydeedy Engine 8 08-19-2010 06:17 AM
4.3 Chevy exhaust manifolds. DoubleVision Engine 5 01-26-2010 08:39 AM
headers??? whats so good about headers, compaired to stock exhaust manifolds? bigno09 Hotrodding Basics 7 11-12-2009 03:34 PM
Stock Engine: exhaust manifolds vs. headers? eastboundanddown Engine 4 01-15-2009 12:09 PM
