-   -   exhaust/petrol pipe clearance (http://www.hotrodders.com/forum/exhaust-petrol-pipe-clearance-190375.html)
nunattax 01-08-2011 01:53 PM
3 Attachment(s)
i tacked up a section of my exhaust today.its within 2 3/8 in of the petrol pipe .is this too close .i was thinking of heat wrapping both the exhaust and petrol pipe and using a heat shield but not comfortable with having them this close.what do the experts think
eloc431962 01-08-2011 01:58 PM
I don't see a problem with it at that distance, But to be on the safe side you could fab up a nice looking heat shield, That's what i would do instead of wrapping the parts. Just build something that has a good look to it so that it don't look bad if someone sees it and you will know you made it . JMO
But if it makes you feel better wrap them up and add a heat shield it will still look fine. I have seen exhaust run from the factory on some cars and such that was pretty darn close, :sweat: But i know where you are coming from and i understand what you mean. :smash: But i think a shied would do the trick JMO. :thumbup:
Cole
nunattax 01-08-2011 03:06 PM
exhaust
Cole
thanx for the feedback,im going to reroute the front section of the hose i can get another little bit out of it i will wrap the pipes and use a heatshield over n out
