exhaust/petrol pipe clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 02:53 PM
Last journal entry: column
i tacked up a section of my exhaust today.its within 2 3/8 in of the petrol pipe .is this too close .i was thinking of heat wrapping both the exhaust and petrol pipe and using a heat shield but not comfortable with having them this close.what do the experts think
ID:	51454   Click image for larger version
ID:	51455   Click image for larger version
Old 01-08-2011, 02:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I don't see a problem with it at that distance, But to be on the safe side you could fab up a nice looking heat shield, That's what i would do instead of wrapping the parts. Just build something that has a good look to it so that it don't look bad if someone sees it and you will know you made it . JMO
But if it makes you feel better wrap them up and add a heat shield it will still look fine. I have seen exhaust run from the factory on some cars and such that was pretty darn close, But i know where you are coming from and i understand what you mean. But i think a shied would do the trick JMO.
Cole
Old 01-08-2011, 04:06 PM
exhaust
Cole
thanx for the feedback,im going to reroute the front section of the hose i can get another little bit out of it i will wrap the pipes and use a heatshield over n out
???about exhaust pipe on 2.2 s10 Robbie Engine 4 05-08-2009 04:54 AM
exhaust pipe hotrod fozzie Engine 1 06-28-2008 09:23 PM
Clearance: driveshaft versus H-pipe Sixtyninemercury Engine 7 05-03-2008 08:23 PM
Exhaust pipe Clearance? Z-Money Pit Engine 5 02-09-2006 10:07 AM
x-pipe, h-pipe and other exhaust questions smlblcks10 Engine 7 11-25-2003 07:05 AM
