Exhaust pipe Clearance?
I am currently in the process of laying out the exhaust system in my truck. I am routing the pipes from the headers straight back alongside of the trans. cross-member. At the point that it passes alongside/under the rear transmission cross-member it seems that ground clearance may become an issue. The lowest point measures 4" from the ground. Does this sound like enough clearance? I can run the pipe on the passenger side over the cross-member but I do not have enough room to run it over the cross-member on the driver's side. Do you think I will run into any problems in the future with it set up this way?
Also, if anyone has any pictures of their exhaust system I would love to see them posted here. I am fabricating this exhaust from scratch and any reference photos would be greatly appreciated. Thanks.
