exhaust pipe diameter for 88 f150? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 07:46 PM
i'm looking to do an exhaust setup for my friend's 88 f150. do you know what size tubing and if single or dual-exhaust? i haven't been able to look under the truck.
Old 02-09-2006, 07:54 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
What kind of engine, and what is he looking for? Something mild or wild, mellow or noisey? Too many options here.
Jason
Old 02-09-2006, 08:08 PM
i just want to know the diameter, not writing for suggestions on mufflers,or recommendation
Old 02-10-2006, 07:15 AM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Then go outside and measure it. You need to be a little specific. It helps when you let people you are asking what engine is in it, makes a huge difference. Go with 2 or 2 1/4 or 2 1/2 or 3.
Jason
Old 02-10-2006, 04:59 PM
like my first post stated, i haven't been able to look under the truck,that's why i'm asking here,not because i'm lazy.just found out from my friend,that does not live close by,that it's a 302.
Old 02-10-2006, 06:20 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
That helps. It is really all up to what he is out for. The biggest issue will be emissions. If you go with a single set up, and the engine is modified, maybe running a single 3 inch would work for him, and still sound good. Of course the parts (cat, if using, and muffler) easy to get from a local shop.
Oooopps, is this truck a dual cat system or one? If one, above would work good. He would not have to worry about the O2 sensors being an issue.
If two cats, go with true duals 2 1/4 or 2 1/2, and again the cats are easily purchased. While he is at it, have him get high flow cats and mufflers of his choice. The O2 sensors and their bungs can be welded into the new pipes easily.
Jason
Old 02-10-2006, 06:28 PM
all he is looking for is more gas mileage,so i thought i'd do an exhaust, an msd box or jacobs,and maybe some factory headers off of another car.and other small things like that.
Old 02-11-2006, 06:32 AM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Then, run 2 1/2 duals with high flow cats. Borla, flowmaster or any high flowing mufflers. Will sound good too.
Bending Exhaust pipe ZeeksChopShop Engine 7 05-30-2004 09:08 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
small exhaust diameter up front and big out back?? smlblcks10 Engine 76 01-01-2004 11:24 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Crossover pipe in exhaust Strick Engine 2 09-16-2002 09:33 AM
