-   -   Exhaust Pipe Expander (http://www.hotrodders.com/forum/exhaust-pipe-expander-72916.html)
johnsongrass1 10-27-2005 02:40 PM
Anyone use one before, Do they actually expand pipe enough to slip over another or just push out clamp marks?
OneMoreTime 10-27-2005 03:45 PM
Exhaust tools
The expander just rounds out an existing pipe..If you need to make the connections then you will need what is called an exhaust pipe Swage which does expand the pipe to allow a slip fit..Different terminolgy..different tool...
OMT
BOBCRMAN@aol.com 10-27-2005 03:46 PM
The cheap ones just push out marks. The expensive ones, some are large fine thread, some are hydraulic assist. Will move some metal...
docvette 10-27-2005 06:28 PM
Doc here, :pimp:
I have one, on the few times I have used it, It only works well if you REALLY heat the pipe while Flaring it...
Otherwise it seems the task is too formidable for a "cold" Stainless steel pipe..as said.."It just leaves marks".
Doc :pimp:
OneMoreTime 10-27-2005 06:45 PM
H'mm good idea
Originally Posted by docvette
Doc here, :pimp:
Doc :pimp:
Doc..it may work to take a rosebud torch and get the pipe red and then use the expander..might get ya by so to speak in a Pinch..
OMT
347mustang 10-27-2005 07:27 PM
we used one from auto zone when we built some headers, it worked great
johnsongrass1 10-28-2005 09:58 AM
Thanks everyone. I found a exhaust shop to "swag" the ends of the tubes I need for a ten spot. I'm replacing the exhaust with a headers and mandrel bend pipes bought from Summit Racing for my truck. Of course that means I gotta change engine too. Seems the exhaust is a little to big now. :D :rolleyes:
