Exhaust Pipe Expander - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2005, 02:40 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Anyone use one before, Do they actually expand pipe enough to slip over another or just push out clamp marks?
Old 10-27-2005, 03:45 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Exhaust tools
The expander just rounds out an existing pipe..If you need to make the connections then you will need what is called an exhaust pipe Swage which does expand the pipe to allow a slip fit..Different terminolgy..different tool...
OMT
Old 10-27-2005, 03:46 PM
BOBCRMAN@aol.com's Avatar
The cheap ones just push out marks. The expensive ones, some are large fine thread, some are hydraulic assist. Will move some metal...
Old 10-27-2005, 06:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I have one, on the few times I have used it, It only works well if you REALLY heat the pipe while Flaring it...
Otherwise it seems the task is too formidable for a "cold" Stainless steel pipe..as said.."It just leaves marks".
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-27-2005, 06:45 PM
Wiki Edits: 3
H'mm good idea
Originally Posted by docvette
Doc here,
Doc
Doc..it may work to take a rosebud torch and get the pipe red and then use the expander..might get ya by so to speak in a Pinch..
OMT
Old 10-27-2005, 07:27 PM
347mustang's Avatar
we used one from auto zone when we built some headers, it worked great
Old 10-28-2005, 09:58 AM
Thanks everyone. I found a exhaust shop to "swag" the ends of the tubes I need for a ten spot. I'm replacing the exhaust with a headers and mandrel bend pipes bought from Summit Racing for my truck. Of course that means I gotta change engine too. Seems the exhaust is a little to big now.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Bending Exhaust pipe ZeeksChopShop Engine 7 05-30-2004 10:08 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 09:04 AM
small exhaust diameter up front and big out back?? smlblcks10 Engine 76 01-01-2004 12:24 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
