exhaust pipe seal leak??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2012, 09:36 AM
briansansone's Avatar
4 chevys and a ford
OK. I attached my pipes back to the manifolds after putting in a new engine.
I have a 2001 chevy express w/4.3l. The seals look like they are ceramic donut shaped seals. One of the seals is leaking pretty bad. I tried tightening, but to no avail. Is there a trick, procedure, or something that i'm missing? Neither seal leaked before I unhooked the pipes. Do these seals wear out? Visually the seals looked fine. Should I just get a new seal?
What about the older style seals? Will they work?
I successfully put in a new engine/fuel injection, and countless other parts and upgrades.......And it is the pipe seal that has me stumped.
Thanks Hotrodders!
Old 05-20-2012, 09:19 AM
dinger's Avatar
I would say replace the gasket, making sure it is squarely set and evenly tightened when you bolt it back together. Some parts are cheap enough that replacing them is better then the aggravation of having the proble. Inspect the ebd of the pipe to be sure they aren't bent or a broken chunk of metal gone. I know the old gaskets would ruin quickly if not properly seated, I don't know about the newer stuff.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 05-21-2012, 03:16 PM
4 chevys and a ford
replace i will.
Thanks
exaust pipe seal leak ???? briansansone Engine 7 06-14-2012 06:27 AM
exhaust pipe Don Meyer Hotrodding Basics 6 03-10-2012 01:48 AM
exhaust X pipe deckofficer Engine 13 01-19-2011 09:28 AM
Exhaust Pipe jbossler Engine 4 07-23-2010 05:37 PM
x-pipe, h-pipe and other exhaust questions smlblcks10 Engine 7 11-25-2003 06:05 AM
