Exhaust Pipe Sizing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2007, 04:29 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Does anyone have the info or a link on how to figure exhaust pipe diameter? I have googled with no positive results.
Old 01-03-2007, 06:07 PM
The easiest way to determine the diameter is to measure it directly with a caliper or similar instrument.
Old 01-03-2007, 06:21 PM
poncho62's Avatar
Wiki Edits: 5
I think he is saying....How do you determine what size pipe you need to use............Am I right?
Ontario Rodders
Old 01-03-2007, 06:28 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Thats the way that I took it also.
Old 01-03-2007, 06:59 PM
1ownerT's Avatar
Wiki Edits: 4
That is correct, I should have been a little more descriptive in my question.
I have searched this site, but found for the most part differing opinions on what would work. don't know if there is some magic formula used to determine size.
I am wondering about my Dodge Dakota, 5.2, performance cam, computer, TB, 1.7 rockers vs. OE 1.6, modified intake manifold, very minor bowl work to the heads. Current exhaust is 1 5/8" primary shorty headers, 2 1/8" collector, 2 1/4" Y pipe, 2 1/2" merge collector, approx 5' of 2 1/2" straight pipe to the muffler.
Thanks
Old 01-03-2007, 07:02 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Check this page out I think its what your looking for, should give you a general idea.
http://www.flowmastermufflers.com/faq.html
Old 01-03-2007, 08:46 PM
David Vizard's rules of thumb:
A straight pipe the length of a typical muffler will flow ~115cfm per square inch of inner cross-sectional area at 1.5inHg pressure differential.
Each hp produced needs at least 2.2cfm of flow capacity to avoid being restricted significantly.
small tubes added to headers for more power?.... sc2dave Engine 10 03-07-2005 06:35 PM
exhaust sizing 66truck4spd Engine 1 06-03-2004 08:52 PM
Bending Exhaust pipe ZeeksChopShop Engine 7 05-30-2004 09:08 PM
Jeep CJ-7 Exhaust w/ SB350 Bud Melman Engine 1 10-24-2003 12:47 AM
Exhaust X pipe configuration Jag Daddy Engine 6 04-02-2003 05:16 PM
