Exhaust Pipe Sizing - Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 07:06 AM
72NOVA454
I have a 1972 chevy nova street muscle car. It needs a new exhaust system. It has a 550 HP Big Block Chevy. The headers have 3-1/2" collectors.
Should I go with an X-pipe type system or just standard dual exhaust or doesnt it matter?
What size exhaust pipes should I use? 2-1/2", 3", 3-1/2"?
I would like some free flowing mufflers that are loud. Can you recommend any particular make or model?
thanks
Lee
Old 07-12-2008, 06:15 PM
well for true duals 2 1/2 should be enough...but if you are going to run a y-piped setup you may need somethin around 3 1/4 inch to 3 and a half....pretty uncommon size tho. Magnaflow makes some great flowing mufflers
Old 07-12-2008, 06:19 PM
I would use a x pipe with 3" and Hooker Aero Chamber mufflers. Nice looking nova by the way!
Old 07-12-2008, 06:30 PM
Everything is HAMMER!
+1, not only would it flow great, it would sound so sexy.
Old 07-12-2008, 06:33 PM
[QUOTE=leejoy]
QUOTE]
The dynomax bullet would meet both of those standards.
Old 07-12-2008, 08:43 PM
A big power boost would be 24-28 inch collectors then 3" H pipe.
If you have room an expansion chamber would be a good move,
then the mufflers of choice for sound. I am a big fan of the Dynomax line and Magnaflow line.
Look into David Vizard's exhaust system design that includes expansion chambers.
Old 07-12-2008, 10:20 PM
X-pipe will help flow and can free up a few ponies. I run warlock mufflers on my 396, they sound incredible, and have knockoffs built in so you can go to straight pipe sound, and performance, in about 1 min!! Easy to set up an electric dump as well (my next project!)
Old 07-13-2008, 12:56 AM
65 Imp SS's Avatar
Here is a site for h.p/c.i. to pipe size http://www.magnaflow.com/07techtips/faq/question10.asp
I run with hookers to 3", flowmaster s pipe, to pypes x, to 3" magnaflow mufflers.
Old 07-13-2008, 07:13 AM
I would run 3" pipe (even though 2.5 would be enough). If you decide on 2.5" (for more ground clearance) then use mandrel bends. A 2.5" system built with mandrel bends will flow like a 3 inch system using crushed pipe.
Make a H or X pipe right after the transmission the use a pair of hooker aero-chambers. If it is too loud, install a pair of 12"x 4" dynomax bullets in line (before the mufflers would be best but after also works).
If you decide you want to quiet and good flow, then install a set of dynomax super turbos.
Old 07-13-2008, 11:15 AM
72NOVA454
wow, my head is spinning now.
thanks for all the tips guys. A lot more information than I expected. Great Job.
It sounds like most of you guys are suggesting an H or X pipe setup. That's fine. I'll educate myself more about it.
Lee
Old 07-14-2008, 08:22 AM
65 Imp SS's Avatar
Well if you need some more reading material this might help, take a look here http://www.pontiacstreetperformance....p/exhaust.html
Old 07-14-2008, 09:04 AM
I have x pipe and thrush glasspacks on my truck, sounds great but not obnoxiously loud ,glasspacks arent broke in yet. Th x pipe gives it a verry good sound.
Shane
Old 07-14-2008, 07:26 PM
http://www.pirate4x4.com/tech/billav...urbo_specs.pdf is a listing of Dynomax Super Turbo mufflers with horsepower capability data listed for single/dual systems.
Relative loudness is also listed with sport being louder than street.
What diameter exhaust pipe to use newdad1 Engine 15 02-07-2008 02:28 PM
small tubes added to headers for more power?.... sc2dave Engine 10 03-07-2005 06:35 PM
exhaust sizing 66truck4spd Engine 1 06-03-2004 08:52 PM
Bending Exhaust pipe ZeeksChopShop Engine 7 05-30-2004 09:08 PM
Exhaust X pipe configuration Jag Daddy Engine 6 04-02-2003 05:16 PM
