-   -   exhaust port blockers ??? (http://www.hotrodders.com/forum/exhaust-port-blockers-103069.html)
Vortech 4.3 11-23-2006 06:28 PM
on a 69 mustang, 351. the rusted headers were taken off for replacement. what was found was exhaust port blocker gaskets. they blocked about 1/3 of the port. i have never heard of these. whats the point ?
kuhn-77 11-23-2006 08:54 PM
the blocker gaskets are used to give better low end torque...but i would never use them b/c they sacrifice more top end than they boost low end thats what i've known them to be for
woodz428 11-23-2006 09:50 PM
It must have a '70 or later Cleveland engine instead of the 351W that came in '69. I've never seen them on a set of Windsor heads., they usually are too restricted already. BUT.. it was and still is a common practice on Cleveland heads to help speed up flow because the lower part of the port slows the flow and creates a deficiency. The "power plates" were not around originally.. they used to mill the edge of the head/exhaust port off and put machined aluminum plates on it that were held by the outer head bolts and then port them together. It was always a port about half the size of the factory port and higher, increasing flow enormously and was standard fare in Pro Stock for many years. It was an expensive procedure for the average guy and stainless exhaust "power plates" were developed with a tongue that goes into the port effectively changing the size and giving some of the benefits of more expensive aluminum port plates with no machining. I think there are more than one made now and not all are stainless.
powerrodsmike 11-24-2006 12:32 AM
Is your motor a windsor or a cleveland? If it is a cleveland, which heads, 2V or 4V?
I never heard of anything like that for a windsor. (I do know of the port plates for the Cleveland, I never heard of them being used in a car with shock towers because of the severe bends required in the headers to exit down.)
If it is a 351Cleveland,(which like woods said, were not installed in any 69s that I know of),could those exhaust gaskets be 2V gaskets on a 4V head?
There is a definate difference in the size and shape of the 2v to the 4V exhaust ports. I know that they usually leak like crazy if you put a set of 2V headers on a 4V head. Or use the wrong gaskets. I know this from personal experience.
A picture of what you have and a positive motor ID would be helpful.
Later,
Mikey
KULTULZ 11-24-2006 02:07 AM
-MPG PORT PLATES-
__________________________________________
Am Looking For Factory/Aftermarket Speed Parts For The MEL (MERC-EDSEL-LINC-TBIRD) Engine Family (383-410-430-462) Produced From 1958 To 1968
Also Early FORD Special Service Tools
-Mercury-Edsel-Lincoln- Engine Forum
powerrodsmike 11-24-2006 05:20 PM
Kultulz to the rescue :thumbup:
Those plates look kind of neat, I wonder if they work.
I was thinking about some of the Parker intake port stuffers for the Cleveland I'm building right now, but they are a pain because you need to fill the floor of the intake runners with epoxy to match. ( it probably wouldn't be a bad idea to do the same for those plates though)
I never knew they made anything out of sheet metal for the exhaust side. :eek: ( I remember the ones that were about 1' thick and the head was machined with a ledge for them to sit on)
I wonder if there is any real gain from the exhaust restrictor plates?
Later, mikey
Vortech 4.3 11-25-2006 08:41 AM
i'm not a ford guy. so i couldn't tell ya. i can get pics though, if there is room to get the camera in there. its not my car, its a friend of a friend thing. i guess he just bought the car. how do i tell if its a C or a W ? will the pics tell ? if so, what do you want pics of ? i can get the pics on monday.
thanx, guys :)
powerrodsmike 11-25-2006 08:51 AM
Cleveland has 8 bolts holding valve cover on, windsor has 6.
Cleveland has thermostsat housing mounted to block, windsor has it mounted to water crossover in manfold.
Cleveland has timing cover cast in to front of block, with just a flat plate cover, Windsor has an aluminum casting about 2" thick with the fuel pump mounted on it.
Windsor looks like a slightly bigger version of a 302, Cleveland looks kind of like a smaller version of a 460
Later, mikey
KULTULZ 11-25-2006 10:40 AM
They worked Mike as they were actually dyno-tested back when they were popular. They actually snap in as to raise the port floors. On the exhaust side, they were more of use raising the floor due to FORD exhaust runners being squeezed by need of them fitting into the uniboby chassis and fitting exhaust manifolds to them (same on 385 Series).
I had a 73 RANCHERO with the 351CJ and that thing ran like a scalded ape (it was bone stock).
