Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Exhaust port size on stock SBC heads?
Old 06-08-2006, 11:57 PM
kringold's Avatar
kringold kringold is offline
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
It's a 305 in a 1984 Chevy Caprice Classic. It has the old biga** mounts, which I think it would be a major pain to pull the motor to cut the mounts. Plus I think I may have to cut too much out for them to fit. See attachments.
Also I would be doing this for a welding class, so I should have everything I need to fab. them, including a tubing bender and a Bridgeport milling machine. I went with the gasket idea and came up with 1-5/16". I may go bigger later to allow for the tubing.
ID:	12688   Click image for larger version
